What brakes for a 2wd stge 3 sapph?
As per title really.... Need to change the brakes very very soon, and was wondering what people would recommend....
And who is doing good deals at the moment??
0-60 in 17 seconds (eek)
Mike, I take it your answer needs to be taken with a pinch of salt, the most expensive brakes won't necessarily be suitable for road use
What would you recommend considering mrsFrog has std calipers and doesn't have money in her budget to change those.
just finding my feet
greg why does she feel the need for bigger brakes as in what problem is she having and whats her setup now
think getting a decent fluid in there and decent pads/discs , if shes warping em thell her to slow down
or seperate discs and bells
broms kit is very very cheap and works very well so also work out what ya got and what ya can sell if for to see if thats not gopnna be far off the new discs and pads as if thats the case then get brembos
Caraholic
Nope, I stand by my comment. Once you have had a car with APs on, the difference is unbelievable (even on the road). I personally think they should be standard kit on any Cossie over 300bhp.
However, if budget is an issue, then my advice is:
Standard OE discs / best pads you can afford (Ferodo DS2500s / Mintex 1155s) / braided hoses / Castrol SRF. You have to make sure that the pistons are not sticking, so may be worth overhauling the calipers.
You will probably find that the poor performance of the OE set up is due to it being 15 years old and never been properly serviced....
1155's aint road pads though and aint the best when cold , i remeber giving me cab some stick at about 1130 in winter and then having to brake for a roundabout and then not being very good , BUT when there warm there the tits hence why i still have em
also agree that servicing the calipers make a difference
Guys.... hold on to your horses!!
Didn't say I wanted to upgrade.... although I wouldn't mind really... would make me feel a bit better knowing the car CAN brake!!! But as hubby has said, apparently I can't afford it...
So my baby will have to do with the next best thing.... without a caliper jobby... simply because she NEEDS new brakes... font pads, and rear discs and pads.
But thanks all for your input. Will get hunting now...
rears discs id use brom as hes the cheapest ive seen for discs
change the fluid to srf or the stuf that christian uses as that makes a difference and wont need changing quite as much as the srf and its cheep too
front pads id say mintex 1144 for normal road use unless ya really agressive and dont mind warming em up ( dont take long btw) then get 1155's as thats what i use
hey mike im giving my opinion as in my cossie i got DS2500's on the front and wait for it,,,,,,,,,,,,,,,,,,,,,,,,,,
halfords pads in the rear, they make such a mess of the wheels ( thank fook there black my wheels) but there 6.13 on a trade card, cant say no can i
And Mike... you got pm... or will have soon!!
Caraholic
MrsFrog,
All of the flexible brake lines replaced with braided ones.
Ginge,
I actually concur, if you have 4x4 vented rear discs or the 300mm vented big discs, you can even get away with El Cheapo pads on the back on track. Forget it with the 2wd solid ones though, as they'll wear out in one 15minute session at Snetteron .
Ginge,
Super Moderator
The best you can afford . APs make a HUGE difference in overall performance...
they DO however wear if the caliper is seized
sorted now though
oh and eagle i agree with the 4pots min, so did cosworth on the mans ( or french ladies) version
im curantly in my bored, jobless self looking at the perfect buget conversion for all cossies and erst's
watch this space
Ok... think I will be going for the Ferr. DS2500 rear and front and some OE rear discs... and as I need a treat, will splash out on breaded hoses!!
Better order before the man gets home!!
i have some recon brake callipers i dont need anymore i have the invoice for the reconditioning too less than 10 months ago and ive had my big brakes on a couple of months
you can have them for £50
ive got some drilled and grooved disks also you can have them for £25 i dont have pads tho the disks are £25 as they have pad deposits on them and lots of dust
im sure there easily removed with a new set of pads
Thanks Craig, but I think I will pass for now. Just put an order through.... and gonna have to go work hard now so Greg doesn't realise what I just done too quickly!!
