how much....
Old May 13, 2005 | 09:21 AM
gingeRS's Avatar
gingeRS
Default how much....
how much is a rear wheel bearing kit for an escort rs turbo?
need to get mine done, just one side, to get it through the mot. to save time, i thought i'd pick the kit up before i take it in.
how much are they, from fords or motor factors? seen one on ebay for 8 quid plus postage is this good, or should i go to fords to get one, as i get a 20% discount.
advice please
its for a S2
p.s. anyone know why my reverse lights arent working, bulbs are fine, have a b and m kit, cant find the reverse switch sensor, whats it look like?
Old May 13, 2005 | 09:57 AM
gingeRS's Avatar
gingeRS
anyone.........?
Old May 13, 2005 | 10:18 AM
GARETH T's Avatar
GARETH T
i got an idea
"mr ford,,,,, how much are rear wheel bearing for a escort rs trubo"
Old May 13, 2005 | 10:19 AM
gingeRS's Avatar
gingeRS
smart arse
Old May 13, 2005 | 10:21 AM
GARETH T's Avatar
GARETH T
fooking hell,, was only having a laugh
Old May 13, 2005 | 10:28 AM
gingeRS's Avatar
gingeRS
me too
Old May 13, 2005 | 10:32 AM
John Laverick's Avatar
John Laverick
The sensor for the reversing lights has probably fallen off (or is gunked in oil so has stopped working). Its mounted on the front of the gearbox just above the cradle/gearbox mount, it’s a small black plug. Giveit all a clean up and it may solve it.
Think wheel bearings are about £20 from Ford
Old May 13, 2005 | 10:34 AM
GUZZLER's Avatar
GUZZLER
wheel bearing, finnis no. 5007 028, £19.87+vat.
choice of 2 reverse light switches, up to 03/1989 6031 219, £10.47
from 03/1989, 6871 978, £10.26
the reverse light switch is located in the front side of the gearbox, behind the intercooler. you should be able see the wires leading to it.
Old May 13, 2005 | 10:36 AM
gingeRS's Avatar
gingeRS
cheers guys. exactly what i needed
now will try find that sensor, will it be a pain to get at from above. will the metering head be in the way?
Old May 13, 2005 | 11:42 AM
John Laverick
You'll struggle from above....my bets are it doesn't need replacing just cleaning up
My wheel bearing guess was pretty accurate
LOOKED
Dec 26, 2010 09:38 AM
