help please over a week now still not running
my big tuurbo esc cos is breaking my balls, it defies to run rite for me. symtoms are, struggles to start when it does (sometimes it will start perfect ) it runs fine until you rev it above 4000rpm then it dies like it's not getting enough fuel or maybe too much but anyhow here is what we have eliminated:- swapped ecu's, coolant sensor, charge air sensor,phase sensor, crank sensor,map sensor, lamda sensor. can anyone help me cause this is really getting me down
Could be fusebox or the main loom multi plugs under the pass' side bonnet vent - they corrode and give wrong signals to the ECU - worth checking as they're both very common issues with the EsCos.
Could also be any of the associated wiring for the sensors......
Good luck with it.
Good luck with it.
rog
30
29-08-2015 11:16 AM
