Efi conversion question
Old May 8, 2005 | 01:54 PM
dh1's Avatar
dh1
Default Efi conversion question
Converting from Mfi to Efi, do you have to use the Efi flywheel? and set the crank sensor in the block or can you use the cps on one of the pulleys?
Thanks in advance Andy
Old May 8, 2005 | 02:33 PM
essexrsturbo's Avatar
essexrsturbo
you can do it either way mate, if you dont want the hassle of takin the flywheel off, use the pully.
Old May 8, 2005 | 03:39 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
IMO using the pulley/s is bar far better as you can set the amount of advance or retard by a mechanical way aswell as electrical. You can also use different sensors for different results and use. If you have an Escort RS Turbo bottom end, only the 90spec blocks had the hole for the crank sensors. This would mean you need to drill a hole in the block and change the flywheel.... which is pointless if all you need to do is change the bottom pulley instead.
I know that 36-1 and the 4 pickup trigger pulleys are available
Regards
Jano
mk3ste
Oct 17, 2021 10:09 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
