do you ever think a cossie will ever push out 1000BHP?
#42
Originally Posted by Danny B
Waynes car made 873hp with the BDT although this was done early 99 and think how tuning has come along since GM have produced 1200hp from a 2.2ecotec
cost?
julian godfrey has just done jt's yb on race fuel and hit a"brick wall"
@858bhp,changed manifolds and all sorts to no avail.I think it was still
using rs 500 plenum and 8X greys set up,in to 800 bhp territory!
puddy
#43
easily possible, just a case of wether or not anyone would bother due to how much it would cost and how it would drive, only way i would want it personally would be if it was nitrous and a medium sized turbo (ie GT40 or less + gas) so that you didnt suffer too much with lag and needing too many rpm.
I suspect it will happen soonish though, wether there is a point to it or not, just cause people like chasing numbers.
#44
Originally Posted by Itsmeagain
Capacity isnt an issue on a turbo motor.
"Jives, why aren't we moving?"
"Sorry, Sir, this new Mercedes doesn't let me drop to 1st gear to get on the boost."
#46
#47
DEYTUKURJERBS
#48
#53
What date do you want for the YB, the first released one to the public (85 IIRC) or when the block first started getting used as a pinto?
Either way, its a reasonable amount before the first skyline motors which were early 90s i think
#54
TO PEAK POWER YOU FOOKIN THICK TWAT
Turbo chargers need to run at higher pressures to supply the same air flow as a larger capacity turbocharged engine, that equals either larger inlet air flow designs allied with lag, or higher compressor shaft speeds and inlet air acceleration. Not so simple to design and build.
Smaller engines deal with higher BMEPs per cylinder, raising chances of auto-ignition. So less ignition advance and lower compression ratios are needed, lowering efficiency.
So with the topic of power bands to the side, capacity is still an issue.
#55
DEYTUKURJERBS
Chip- RB**DE engines was first released to the public in a car in 1985 too, same as YBs
Anh- Feck off, point is, we are talking purely 100% power, nothing else in the slightest, and capacity has very very little effect on the maximum available power of an engine, if all other aspects are free
Your just nit-picking to look like a clever twat, you dont contribute fuck all to this site so I dont know why your here...
#56
You're not getting out of this one, you shot yourself on the foot with sweeping generalisations and condecending cod sh1t. If you can't accept educated scrutiny then you should keep schtum on things that are beyond your scope.
I'll happly discuss engines and cars politely with anyone, but I'll equally be happy to put the end to some bullcrap that is arrogantly whored out on this board or any board for that matter.
#58
i think keith duckworth summed it up,, but i cant remember his exact quote
"theres only two things that restrict power of a turbo engine, heat and mechanical strength, volume has very little to do with it"
something like that anyway
#59
Cosworth also said there was no future with electronic engine management...
The less capacity you have, the more problems you will face to get top end power. Duckworth's comment pretty much a contradiction if you look into it.
#61
DEYTUKURJERBS
rofl@condecending pot-kettle-black at the most unhelpful person on here
i elaborated to say "very very little effect if ALL other aspects barring capacity are free" which is bloody true, but still decides to argue
what you say above is true, hence why i elaborated before you even posted that, but i mean FFS we only talking about getting 1000bhp out of a YB here for gawds sake
Nit-Picking StepbyStep
http://ohioline.osu.edu/b893/b893_13.html
#62
As this thread is about YB engines i assume the capacity comments are too, ie a 2.0 compared to a 2.2
Peak power and amount of boost used will be much of a muchness in both engines, but the 2.2 will be a slightly higher CR
The amount of boost needed isnt so much a factor of the bottom end, more of the flow potential of the head, as the vaxuum produced by 2 or 2.2 litres isnt enough of a difference to make much odds when there is 50lbs of boost forcing its way in.
It will have an effect, but not much to peak power, far more to where the turbo spools etc
#63
it's all useless rambling from someone who talks more than listen
#65
It's a scary chain of events to think about, that's why alot needs to be considered when making huge power from limited capacity.
#66
DEYTUKURJERBS
ooooh, defensive/childish as theres no reply as you know what im/we saying is bloody right.
You NOT wrong, what you are doing is pathetic nit picking which dont even have a real point as id reply'd with that slightly more elaborate explanation before you posted what you did...
Chips saying it, gareths said it, ive said it, and gawd knows how many millions of people have said it in the past, your NOT wrong about it having an effect, but for all intents and purposes it has no substantial effect to someone building a 1000bhp YB or any remotley similar engine.
Of all the trade-offs, capacity has the least effect to overall power a turbocharged car makes.
Infact lowering the capacity by shortening the stroke may even be an advantage as then you might have more revs to play with to produce the power.
#67
Anh, you have missed the point really mate, those pressure are dictated by unswept volumes not swept.
If you have 10 litres of mixture after combustion in a cylinder, its only the timing and the amount of space above the piston crown that matters. not the amount below it.
Thats the whole point of lowering CR
a 7:1 2000cc motor can handle the same amount of pressure as an 8:1 2300cc motor (roughly)
#72
Alps Pacino
Probably about 1050bhp........... then leading onto Chips question...... the H-section rod went walkbout!!! Very interesting topic lads!!
#76
Originally Posted by Ian@Racetek
i think a cossie could deffo reach 1000bhp just a case of money
#77
Cossie crew
Nah, Im just joking, it made 576bhp on the rollers but an issue meant the boost ran wild (datalogged at 52psi on a GT35) and blew it up. It felt like 1000bhp though!!
#80
I think the only way to get over 850bhp is to weld the head to the block and have titanium conrods!
Anyway, isnt 858bhp enough? Or 600bhp for that matter?
