coilover on a saph
Old May 6, 2005 | 08:10 AM
wimwerf's Avatar
wimwerf
Default coilover on a saph
ive heard if im fitting coilovers on my saph i have to modify the bodywork on the rear because the spring is on a different place then....
is this true.....
Old May 6, 2005 | 08:29 AM
Jim Galbally's Avatar
Jim Galbally
"modify"
big hemmer and a few hits and all is well
and no its not as bad as it sounds
Old May 6, 2005 | 08:34 AM
Lillford 500's Avatar
Lillford 500
I read somewhere that you have to use a rear strut bace with rear coilovers cause the body wasn't designed to take that kind of weight on the strut tops.
Don't know how true that is though??
Old May 6, 2005 | 08:51 AM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
probly very true.especially if the car is getting abit tired.
Old May 6, 2005 | 08:58 AM
EssexBoyRacer's Avatar
EssexBoyRacer
I've been told the same, u need to seam weld around the stut tops for extra strength.
Old May 6, 2005 | 09:08 AM
philthewheel's Avatar
philthewheel
Default coilovers on saphs
You should fit a rear strut brace because with the standard suspension set up the weight of the car is shared between the strut top and the spring mount, but with coilovers all the load is on the strut top
Old May 6, 2005 | 09:14 AM
Micky The Finn
Former Sponsor
or fit a cage.
Old May 6, 2005 | 09:36 AM
foreigneRS's Avatar
foreigneRS
Testing the future
on a standard setup, the spring takes the main load directly into the "chassis rails", and only the damper load is going through the strut top.
with coilovers, you have the whole load going into the strut top area. i would want to make sure it's strong enough to take it over repeated loading.
what jim is talking about is you may need extra clearance for the increased diameter of the coil spring over the std damper on the inner arch area, and has nothing to do with the increased loads going through the strut top mount.
Old May 6, 2005 | 03:04 PM
wimwerf's Avatar
wimwerf
so its true....
Old May 6, 2005 | 07:35 PM
Taz's Avatar
Taz
Visitor from the Darkside
I have coilovers on my saph and they do not hit. I did not modify the bodyowrk at all.
G
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
