Plenum Spacers...who this then??? Do they work???
Minor overlaps may be present, this is due to the fact Cosworth plenums are of cast construction, cast construction by it's very nature is not as accurate as a machined part , meaning each plenum will vary to some extent making it impossible to make a generic exact match spacer plate.
(Photos/images for illustrative purposes only. Product's appearance/function may differ slightly. All dimensions are approximate and may vary +/- 0.1mm
cosrush - you might find that the throttle body is moved out and caches on the 'lump' in the engine bay on the rush.
is the problem with the 2wd plenum not in the elbow anyway rather than the plenum capacity
It is my understanding that it is indeed the elbow that causes the restiction between the throttle housing and the plenum.
Just saw them on Ebay, and remember seeing one a while ago, and wondered whether they make much of a difference...
Im not about to get one for mine....
A friend of mine has a Phenolic spacer on the inlet to the head, and the reduction in transfer of heatsoak from the head to the plenum is greatly reduced, such that it doesn't cause heating of the air around the ACT sensor fooling the ECU to thinking its hotter than it is.... His tests showed a good result after boosting against running without one...
Nice pix...
Thanks for that
So back to the plenum spacers.....
I can see how they increase the volume within the plenum, but how does that help when the volume in the throttle elbow remains the same....???
Any idea's???
Thanks for that
Any idea's???
Originally Posted by CosRush
Nice pix...
Thanks for that
Any idea's???
Thanks for that
Any idea's???
Rod
PLEASE BARE IN MID THIS...
IF the spacer works and gives more BHP you may well require a re map to stop detting your YB to destruction!!!!
Leave well alone any BHP increasing mods that aint taking into account in your chip.
Feel free to aint gimmicks that make no difference whatsoever except make you "feel" your getting more bhp cause the maker says so
Shame somebody cant fit and test to show results....
Like i said, im only asking to try and understand what is happening, as i realise the volume of the plenum is increased but the volume through the elbow isn't therefore there should be no increase in airflow....
and its not something im considering doing....
I would have one of them swedish plenums if i had any money....
and also a live map,new ECU with Closed Loop Boost control and fuel control, Greys,fully ported head etc etc....
Anyone know the winning lottery numbers
What spec engine is yours Rod???
Engine Specification
2150 c.c. DOHC 4 cylinder 16 V : Nikel linered block: 7.2:1 pistons : custom con-rods : custom crank: Group'A' Big-end bolts : Double length head studs : High pressure oil pump : Baffled sump: Gas flowed & ported head : Uprated valve springs : Bronze valve guides : WRC Head gasket :
M.A Development profile cams : 4 x 1000cc injectors : Autronics ECU/CDI : 4 coil ignition :Swirl Pot: Automotive fuel pump: Spaced RS500-Throttle body :
GT40 Turbo-charger : External wastegate : SPEC-R Turbo Pre-Radiator : Turbosmart boost controller: SPEC-R Group A Dump valve : Induction kit : RS500 Intercooler : Large Capacity Radiator : SPEC-R High Pressure Header Tank : Samco Hoses : SPEC-R Group A Breather System :
Tubular exhaust manifold: 3 1/2" BTB Stainless Steel Exhaust : Mapped Water Injection : Oil-Cooler : 15v accuvolt system :
Nitrous
Highpower Direct-port system: Powermax Progressive controller : Purge valve:
Brom,
Funny you say that...
I was thinking about that last night, the airflow into the plenum through the elbow fills the plenum in and around the Trumpets.
The airflow has to flow into the trumpets and thus into the engine.
So by adding the plenum spacer, you are increasing the volume directly in front of the trumpet, so therefore surely that should allow for more airflow to flow into the engine purely as there is more space for the air to move in...
Any thoughts....???
Any thoughts....???
Rod does a standard valved head flow 700bhp though ?
Holy Cr@p.....
Nice spec ...do you know how much Power/torque you're making???
On gt35 made 614bhp/508ft-lb @ 2.2bar on Pump Fuel more on race. Mapped for 2.5bar on road so circa 630/520 ish. New Turbo figures as yet unknown but 650+ on pump & 700ish on Race & 800+ on Nitrous are the targets.
Rod
