5th injector - when is it needed?
Old May 4, 2005 | 12:39 PM
Wazzzer's Avatar
Wazzzer
Default 5th injector - when is it needed?
Just wondering at what power a 5th injector is needed on the ERST?
Also at what power is an uprated fuel pump needed?
Old May 4, 2005 | 12:46 PM
Jim Galbally's Avatar
Jim Galbally
depends on the car, some lean off at about a bar, some are happy up to 22psi! the good 'ol randomless that is KE-JEt eh!
Old May 4, 2005 | 12:48 PM
Oranoco's Avatar
Oranoco
Mine was running 20psi on standard KE Jetronic. The 5th injector was added and boost was raised to 25psi
Old May 4, 2005 | 01:49 PM
Wazzzer's Avatar
Wazzzer
what power did yours make on 20psi mate? and was that with standard fuel pump?
Old May 4, 2005 | 01:59 PM
CabrioTurbo's Avatar
CabrioTurbo
Your car will still need setting up if its running 20Psi on ke-jet.
A fuel modification will be needed to supply the extra fuel required for the extra air your engine is consuming.
this can be done with the standrd ke-jet fueling and all that is required (as far as i understand it anyhow ) is a pressure increase.
the problem is that the ke-jet will overfuel on idle and mid throttle but will be fine on WOT.. this isnt a problem TBH as it will cool the bores etc.
The only thing is it will sting your wallet as it will gobble fuel hence why most people will go for a 5th injector after 20 odd Psi as it is MUCH more economical than running modified ke-jet only.
Old May 4, 2005 | 02:40 PM
Wazzzer's Avatar
Wazzzer
hmmmm what is this fuel mod then mate?
Old May 4, 2005 | 02:41 PM
Jim Galbally
wes, you connect the wodgeamaflick to the googlewotsit and turn the adjuster 3 to the left 2 to the right then shake it up and down
Old May 4, 2005 | 02:43 PM
It's Czech Mate's Avatar
It's Czech Mate
Wont you get borewash if it's overfueling lots tho?
Old May 4, 2005 | 03:52 PM
Oranoco's Avatar
Oranoco
It made 200bhp on 18psi with an old style Pace interwarmer. It was increased to 20psi but was never dyno'd before the 5th injector went on. Still on standard fuel pump now with no issues . Pumps been on at least 9 years without being touched as that's how long I've had her for
Old May 4, 2005 | 03:56 PM
ballin's Avatar
ballin
thats what i was thinking?
Old May 4, 2005 | 04:03 PM
gingeRS's Avatar
gingeRS
lucky boy
i went through 4 pumps in a year once. wasnt expesnive but a pain in the arse to change
10 quid from scrappys then an afternoon under the car in the road, problem was, when the petrol leaks out onto the road it melts the tar in the asphalt which then promptly sticks to your skin and is a real nightmare to get out
Old May 4, 2005 | 04:39 PM
Westy's Avatar
Westy
nutter Ginge
4 in a year tho Not had to replace one yet.. had the car 6 years
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Toe Knee
Aug 23, 2015 08:31 AM
Aug 8, 2015 07:12 AM
col93saphcos
Aug 7, 2015 03:21 PM
