Its moved, cant be long now
Old 02-05-2005 | 02:22 PM
  #41
ADUSR33's Avatar
ADUSR33
a nice clean saff just does it for me
Old 02-05-2005 | 02:28 PM
  #42
Andreas's Avatar
Andreas
Chute is lame, get some reverse thrusters.
Old 02-05-2005 | 02:59 PM
  #43
pee vee's Avatar
pee vee
nearly there then mate.
them wheels look way better too lol
good luck !
get a chute! would look cool as fook if nothing else lol
Old 02-05-2005 | 03:01 PM
  #44
Originally Posted by Matt
sexy looking turbo
thought the air filter was always boxed out the way before rod?
It will be after the 3 1/2" exhaust is fitted, takes time, & nothing used before fits, this has been a night mare had three visits to Fabricator over the weekend & its 80 mile round trip each time getting bits made as I found a prob, Henry even did a job today after I cheekly rang him up early this morning & said I had to have a bit made NOW!!. He worked as fabricator for Williams F1 for 5 years & is superb, hes working on Sunnys car & an Escort Cossie at the mo.
Rod
ps. Its now ready for the Exhaust to be fitted, even cleaned it. .
Old 02-05-2005 | 04:04 PM
  #45
Matt's Avatar
Matt
i see, just wondered, sounds like a good man to know does this henry
Old 02-05-2005 | 08:06 PM
  #46
Stavros's Avatar
Stavros
DEYTUKURJERBS
Just move a few of the blue plastic wrapped tyres out the way at the end of brunters just in case so you can run right thru the parked cars in an emergency...
We did that last Wednesday and fookin good job too as on the 200mph run the Corrollas brakes failed and had to take the emergency exit i made
Good thinking by Adrian too as i didnt expect it at all...
Old 02-05-2005 | 09:20 PM
  #47
Danny B's Avatar
Danny B
Originally Posted by MADRod
Originally Posted by pugo
i am being quite serious here, why not fit a chute to give you another few feet before the breaking zone and for that just in case security ???????????
a lot can go wrong very very quickly at that speed and your run off isn't very big
a concerned Pugo
Yes have looked at this already, its a neat kit & can be talen off easily.
The jag diff is used for this type of thing all the time. Its probably illegal at totb so i will prob not fit it.
Rod I would highly recomend fitting a chute in the interest of safety, how ever it is very important where they are anchor'd, if wrong the rear will start to fly but when fitted correct could save you and the car stopping and also when out of control. As for TOTB they are extremely stupid if they object to cars running them, they wont aid MPH as TOTB best is over a set distance therefore there a safety feature.
If you decide on a chute feel free to call if you need advise.
Old 02-05-2005 | 11:25 PM
  #48
Fastmaul's Avatar
Fastmaul
K155MYRS
Good Luck with it again Rod
*I will sell the secrets of that turbo to anybody who pays me very well!!!!*
J/K Rod.
Old 03-05-2005 | 08:09 AM
  #50
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
HOoe all goes well Rod.
Old 03-05-2005 | 08:32 AM
  #51
Paul Eggleton's Avatar
Paul Eggleton
Good luck Rod, I would seriously think about running a cage at those speeds too
Old 03-05-2005 | 08:42 AM
  #52
Steve, does the speed still "count" if you end up going through the emergency hole you have made in the tyre wall, as i thought that the contest everyone was engaging in was what top speed you could get up to and then stop, obviously if you dont have to completely stop at the end it gives you longer to accelerate?
Not that i care either way very much personally, but just thought a few people might start knocking Rod for that if he did what the corrolla did and "cheated" by breaking too late and having to use more space.
Old 03-05-2005 | 09:01 AM
  #53
Porkie's Avatar
Porkie
Chip, its an escape route if your brakes fail. You really wouldn't want to plan to use it. The amount of ground you are covering at that speed compared with the amount of speed the car is putting on over say 195mph I can't see that little extra making that much difference at all. Just my opinion.
Old 03-05-2005 | 09:05 AM
  #54
Porkie thats my opinion too, but it wont stop all the Rod-bashers having a go at him if he ends up needing to do that.
They will just say he was cheating and couldnt do it in the allocated space.
Old 03-05-2005 | 09:34 AM
  #55
Porkie's Avatar
Porkie
Well if they do start saying that shite, I'll tell em they are losers who haven't got a clue what they are talking about
Old 03-05-2005 | 09:38 AM
  #56
Exactly the same approach i would personally take to those who view it as invalid if its a "on gas" speed TBH.
But Rod seems to care about the opinions of such fools for some reason!
Old 03-05-2005 | 11:46 AM
  #57
Have seen a few go through the end, Mark did it once & vowed never again, its a car park & a bit hairy. Its OK unless you are out of Control & sideways, best avoided. At 200mph your doing 100m second so makes little difference as its prob only another 1 second or so on the throttle, I dont think anyone would set out to cut it that fine. .
Old 03-05-2005 | 12:06 PM
  #58
JoeE30's Avatar
JoeE30
Good luck Rod....
Old 03-05-2005 | 05:19 PM
  #60
ImaRacing 700's Avatar
ImaRacing 700
Rod you found a follower in Chimp
A.t.p
23-10-2015 07:54 PM
Brickhouse
14
03-10-2015 07:28 PM
sridgett
01-10-2015 07:30 PM
Fudgey
21
30-09-2015 06:19 PM
Fil
30-09-2015 12:08 PM
Quick Reply: Its moved, cant be long now
