EFI conversion on S2 question
Old Apr 24, 2005 | 09:16 PM
david's Avatar
david
Default EFI conversion on S2 question
What do you use in place of the flywheel for the CPS to take a signal from ? my block obviously aint got a hole for a cps and im not wanting to drill it. Is there anywhere or anyone who sells something suitable ????
Old Apr 25, 2005 | 06:07 AM
JesseT's Avatar
JesseT
The block is drilled in no time actually. Really soft cast material. I have done this with my car when I installed the Megasquirt'n'spark extra management.
Old Apr 25, 2005 | 06:47 AM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
You can use the CPS and pully teeth from a 1.8 CVH EFI Sierra
Old Apr 25, 2005 | 08:27 AM
david's Avatar
david
Jesse, I really dont want to have to drill it if I can find another way
Adam, I was told that the Sierra CVH was to wide to fit in the engine bay please tell me you can do it though
Old Apr 25, 2005 | 08:37 AM
Ginge !'s Avatar
Ginge !
just finding my feet
ya have to machine the bottom pully to allow it to fit
not topo tough though
Old Apr 25, 2005 | 08:39 AM
david's Avatar
david
Ginge how much do you need to take off it roughly ??? can get it done at work
Old Apr 25, 2005 | 08:50 AM
Adam_BlackRS
Ex Ford Man
4-5mm IIRC
Old Apr 25, 2005 | 08:56 AM
david's Avatar
david
Adam would I be right in saying that its machined on this side ??
And can you fit the pulley with the engine still in the car ?
Old Apr 25, 2005 | 09:02 AM
essexrsturbo's Avatar
essexrsturbo
speak to jano, he sells these parts ready modified to bolt straigt on, no need for any work.
Old Apr 25, 2005 | 09:06 AM
Ginge !'s Avatar
Ginge !
the other side is machined !!!!, ya can fit the pully with the engine in the car but ya gotta lower the side of the engine though !!!!
jano suplied my parts and tbh was at a very good price hence why i never bothered to machine me my self
Old Apr 25, 2005 | 09:09 AM
essexrsturbo
i think this woz the bit that suited you bigbal
Old Apr 25, 2005 | 09:13 AM
Ginge !'s Avatar
Ginge !
yeah telling me, why spend all that time and petrol to get small nigly things done when ya can give a give a drink and he has it already done and ya just collect it
Old Apr 25, 2005 | 09:31 AM
david's Avatar
david
Other side ????
Got a pulley here and a lathe in work or else I would have just bought it from Jano
Whilst were on the subject, what did you do about the alternator ? change it to a sierra one or just swap the pulley's over ?
Old Apr 25, 2005 | 09:41 AM
Adam_BlackRS
Ex Ford Man
Outta side to be machined, and yes... you need to lower the engine to fit...
I have got a complete post when i did the conversion myself but it seems to have disappeared...
Anyway, with the alternator.... you need the 1.8 CVH EFI Sierra alternator bracket with 4-5mm machined off the left side of it, adjustable arm and pully...
Old Apr 25, 2005 | 10:03 AM
david's Avatar
david
Adam thats spot on mate
Old Apr 25, 2005 | 03:13 PM
skeld's Avatar
skeld
how do you go about doing this off the cam pulley?
Old Apr 25, 2005 | 03:22 PM
essexrsturbo
use a phase disc, with a crank sensor mounted above it on a bracket
Old Apr 25, 2005 | 03:38 PM
david's Avatar
david
Any pics of this ??
Old Apr 25, 2005 | 04:59 PM
Tim's Avatar
Tim
why not use cossie efi and make a 4 point trigger and make your own cps bracket for the sensor ? easy as and loads better efi.
Old Apr 25, 2005 | 07:46 PM
david's Avatar
david
Had a fiesta turbo ecu, a 3i efi loom and a S2 with a fucked k-jet system all sitting around so made sense and easy to throw it all together
mk3ste
Oct 17, 2021 10:09 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
