St170 connect
St170 connect
Hi new here I’m doing a st170 swap in my 2010 connect couple of questions
what throttle pedal do they use and do the st170 drive shafts fit the connect hubs thanks Dave
That’s the only bit that not fitting so far driveshafts fit the connect hubs so can keep my 5 stud as already have rear discs power steering all plumed up used the connect rad pack had to use the st170 pipes just left with the wireing and throttle pedal the connect ecu is in the wing and focus is in the drivers foot well and has more plug that go in to it we’re the connect loom ends at the ecu so might have to put the focus loom in the connect then just the fuel system looks like a straight swap for that
