T35 turbo.
T35 turbo.
How much could you port the shroud inlet on a T35?
I've seen someone on here has theirs ported to 4", but I think it's a bigger turbo than a T35!
Don't know if we will find out though pgt, seem's like you have to be a well established member to get attention around here lol. Hopefully though, one of the tuners or someone can help us.
wouldnt be any point as far as i can see porting the tunnel unless you were increasing the comp wheel size, i have a t34 thats been machined for a t38 comp wheel etc but thats the only point in doin it as i see it, hth
Originally Posted by pgt
i wondered this too. mine is about 50mm inside diameter and the pipes to the intercooler are 60mm??
mines 100mm but mine isnt a t35.
I wouldnt personally mess about with the design characterics of the turbo, there designed to perform with the comp housing how it is, if you port the inlet, if could seriously affect the way the turbo performs.
Originally Posted by Alloy
So what's it ported too then? Could you get it to 4", or is that not possible? Or even easy?
it will, i think strut brace.
all to do with pressure and flow.
I.e forcing 40CuF a minute through a huge hose and forcing 40CuF through a hose half the diametre, the velocity of the air is masssively increased, and we know what that does to turbos
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOS T
All in my opinion
All in my opinion
I'm not going to do it mate, I just seen someone on here had a "4" ported inlet shroud with 3" outlet". So it had me curious, that's all, thank's for the help though guy's.
All in my opinion
All in my opinion
YAY
Look's like I've started my first interesting topic lol
I'm not sure you're talking about the same part strut brace, but I'm certainly no expert myself and don't know exactly what bit would be classed as the inlet shroud.
Shit, you changed it already!
Anyway, that's what I original thought, the bit with the arrows pointing to it. But I'm now thinking it's a bit further in than that mate.
yeah im talking about the same part. do you think air just flows into there?
No
Its sucked, the comp wheel causes a vacuum effect.
so back to my theory, if you suck the same amount of air through a smaller hole, the air will be travelling faster
No
So am I right in saying yours is around 4 inches ( roughly 100mm )? I'm no good at maths
What turbo are you running BTW mate??
It does make sense strut brace, put it this way. You get a straw and suck as hard as you can, then get a garden hose and do the same thing, you're easily going to be able to suck more air through the hose!
Strut its just a theory i had nothing more
But would sucking in more volume than the compressor wheel could deal with have an adverse effect? i.e increased lag? or am I just being thick and getting it wrapped round mi ass?
Strut just to through something else in the pot!
Headwork is only a few mm's in variant and that varys bhp levels from 380-1000
Just a theory
With forced induction small alterations are magnified massively
Just a theory
yeah , but the head is an enclosed space inside so porting etc allows the air/fuel to flow faster through a restricted pressurised space, the front of a turbo aint restricted in any way,it just goes straight into fresh air, it already has an enormous hole in the front and the hole is big enough to flow more bhp than the comp wheels/ housing can deal with anyway, its a bit like saying if you fit a bigger air filter hose you will get more flow, there is a point that comes where the comp wheel can only draw so much cfm regardless how big the hole is and i think that the std hole on the turbo is bigger than that as standard so increasing its size is negligible, by yor way of thinking if you took the airfilter hose off altoghter you would get more air flowing ? i cant see this being the case as the turbo's arnt restricted on the intake
if you made sense of my babble there
you put anything in the way of air it will slow it down
other than of course the venturri effect
e.g1. turbo with a std hose on it and an induction kit on
e.g.2 turbo with a bigger diameter hose on but with same induction kit on
the pair would flow exactly the same as its the air filter thats restricitin flow NOT the pipe, to increase flow you would have to have a less restrictive air filter.
the same theory applies to the width of the housing tunnel as the restriction is not the size of the tunnel but whats bolted on the end ( air filter )
you see what i mean ?
intersting topic either way
ok going on that theory, why arent turbo shrouds ported out to the size off the compressor wheel?
Because Lag will be massively increase.
You say that turbo engineers design turbo's with the shroud smaller because they dont know any better?
Its obviously that way for a reason, and i think its there for this reason.
The tapered housing acts as a funnel\restriction, this forces the the air into a smaller area thus increases the velocity of the air, and creating a quicker spool up time.
measured mine last night and mines slightly bigger than a GT40, but doesnt flow as much as one
That is one Stonking turbo.
Another pic of my T61R, looks a little small now compared to that GT42
I think he better give that turbo back to the drag car he stole it off...
These thing's must be so laggy, would fancy sitting in a car with a GT42r running an anti - lag set up none the less, nappies would be adviced!
