Cossie plenum spacer
Old Feb 11, 2020 | 03:16 PM
Adam-M's Avatar
Adam-M
Default Cossie plenum spacer
Hi all
when fitting a 10mm plenum spacer does it affect how the fuel rail bolts up as i’d imagine it means it will be 10mm further away from the injectors? Using an anembo billet rail on a hart plenum.
thanks.
Old Feb 11, 2020 | 06:31 PM
stevieturbo's Avatar
stevieturbo
C**t
If you've the Hart plenum, why bother with the spacer ?
Old Feb 11, 2020 | 07:00 PM
Caddyshack's Avatar
Caddyshack
Never heard of a spacer on the hart?
Old Feb 11, 2020 | 07:03 PM
stevieturbo
C**t
It would seem totally pointless.
Old Feb 11, 2020 | 08:58 PM
Mark Shead's Avatar
Mark Shead
I had one on Rods older spec Not needed under 700hp. Above it on a larger capacity engine the larger volume plenum helps with power.
Old Feb 11, 2020 | 09:02 PM
Caddyshack's Avatar
Caddyshack
I did wonder if it might be a big power thing.
Old Feb 11, 2020 | 09:08 PM
scoooby slayer's Avatar
scoooby slayer
Learn something new every day, has mine got a spacer on it mark ?
Old Feb 11, 2020 | 09:18 PM
Caddyshack's Avatar
Caddyshack
no, yours is not hart anymore either.
Old Feb 11, 2020 | 09:34 PM
scoooby slayer
Yeah mines got jenvey plenum and itbs, but I presume could still have spacer on it ?
Old Feb 12, 2020 | 02:03 AM
Adam-M's Avatar
Adam-M
Reason I ask is to fix my fuck up I made lol, the o-ring Grove on the flange had a small crack and the face was generally pitted ect so me in my wisdom decided to grip it in the mill at work and machine the flange to remove the groove and clean it up ect.....didn’t realise till I got home that there is a small lip that needs to be a certain thickness for the trumpet section to locate into, now it’s too shallow and the trumpet section bottoms out before closing the gap. So I figured a spacer would fix this, not bother about performance gains.
Old Feb 12, 2020 | 02:04 AM
Adam-M's Avatar
Adam-M
Plan is too use a cometic gasket like a normal plenum instead of the o-ring
Old Feb 12, 2020 | 05:55 AM
Mark Shead's Avatar
Mark Shead
The volume on the Jenvey doesn’t need a spacer now.
Mark
Old Feb 12, 2020 | 08:11 AM
nixon_2wd's Avatar
nixon_2wd
Just mill the clearance needed for the trumpets?
Old Feb 12, 2020 | 01:38 PM
Caddyshack's Avatar
Caddyshack
I guess that could weaken it and who knows how the flow could change- may as well fit the spacer.
Old Feb 13, 2020 | 07:01 AM
wes's Avatar
wes
Originally Posted by Adam-M
Hi all
thanks.
If the thickness of the fuel rail lugs on the plenum are still 10mm thick you might be able to simply mount the fuel rail on the other side of the lugs?
kaisersolsay
Apr 27, 2011 07:56 AM
proboscus
Oct 3, 2008 10:19 PM
proboscus
Sep 3, 2008 08:06 PM
proboscus
Jul 25, 2008 07:59 PM
tony perth
Apr 19, 2007 12:10 PM
