Waterless coolant
Old 20-01-2018, 08:14 PM
Rsmat
300+
Rsmat's Avatar
Default Waterless coolant
Yea or No to running it on my new build..hearing mixed views on it .
Thanks Mat.
Old 20-01-2018, 08:17 PM
gcfcos
gcfcos's Avatar
I can't see it being a bad idea mate, won't corrode like water mix, only get expensive if u get a coolant leak or something I would imagine
Old 20-01-2018, 08:22 PM
Caddyshack
Caddyshack's Avatar
I used it and it seemed to cause leaks that weren't there before, I recently swapped back to deionised water and anti freeze and it reacted an frothed up even though I had drained the engine. Marks shead said to use water and anti freeze so that's what I am gonna do.
Old 20-01-2018, 08:23 PM
Caddyshack
Caddyshack's Avatar
I have a big bottle of flush fluid if you want it, it is expensive stuff.
Old 20-01-2018, 08:34 PM
stevieturbo
C**t
stevieturbo's Avatar
water and antifreeze have worked....almost forever
Is there some sort of problem you're trying to fix with this ?
Old 20-01-2018, 09:04 PM
Rsmat
300+
Rsmat's Avatar
No problem at all ..i just want what's best for the new engine once fitted .
Old 21-01-2018, 09:07 AM
jonfoc
jonfoc's Avatar
Water and the correct antifreeze Mat. Correct antifreeze in the correct ratio is all you need. If you use the Evans waterless stuff and pop a hose whilst out it's a recovery truck home unless you carry spare stuff with you.
Rsmat (21-01-2018)
Old 21-01-2018, 09:11 AM
Caddyshack
Caddyshack's Avatar
The Evans stuff says in an emergency you can add water but you lose all benefit and then have to flush etc but I flushed mine out and refilled with antifreeze and deionised water and it all went frothy so I am having to flush again.
I wouldn't use it anymore.
Rsmat (21-01-2018)
Old 21-01-2018, 09:19 AM
jonfoc
jonfoc's Avatar
That's what I mean Toby. It's not cheap in the first place so they're onto a winner and you're spending a fortune. It's a problem that isn't really there.
Old 21-01-2018, 09:59 AM
Rsmat
300+
Rsmat's Avatar
It's not worth the hassle guys ..anyone know a really good antifreeze to use with dionised water ... 50/50 it is .
Old 21-01-2018, 10:36 AM
stevieturbo
C**t
I just use Quantum red anti-freeze....however pretty sure whether there's iron/aluminium in the system can dictate what is most suited.
As some might oppose rust better than others.
Old 21-01-2018, 10:44 AM
slammedorion
slammedorion's Avatar
Cvh should have blue anti freeze
Old 21-01-2018, 05:58 PM
markk
markk's Avatar
Nope. !
Rsmat (21-01-2018)
Old 21-01-2018, 07:03 PM
Rsmat
300+
Rsmat's Avatar
I won't be using it will be using a good antifreeze at 50/50 mix
Old 21-01-2018, 07:17 PM
Brendan
struggling with reality
Brendan's Avatar
seems ok in mine, I have not stress tested it yet though! I like the idea that it will not boil over and pressurise the system... I have it in a CVH engine.
Rsmat (21-01-2018)
Old 22-01-2018, 03:15 PM
bassboy
bassboy's Avatar
From things I have heard, I would never run it...a few classic 80s era engines that I know of have gone up in smoke because of the waterless coolant whereas the ones using a traditional water/antifreeze mix, are still going strong!
Glad to hear you are steering away from that decision!
Rsmat (23-01-2018)
Old 23-01-2018, 09:09 AM
gingeRS
gingeRS's Avatar
if you find it runs a little hot, then run a little less antifreeze
Old 23-01-2018, 09:34 AM
Rsmat
300+
Rsmat's Avatar
I can't see me having problems with temps ..im just asking as now ive got a brand new engine i want what's best for it that's all and it seems a good 50/50 is the way .
Old 23-01-2018, 12:07 PM
martysmartie
martysmartie's Avatar
That means it's IAT, which as a rule of thumb cars prior to circa 1996 should use.
Did they have that when new?
Martin
Old 23-01-2018, 05:54 PM
Brendan
Brendan's Avatar
if you are running a highly tuned engine than you might go down another route of using something called water wetter if you do not want to use waterless coolant, it is by a company called redline, and it makes the water coolant mixture more effective at transferring heat out of the engine. I have only noticed a marginal benefit from this though.
Rsmat (23-01-2018)
Old 24-01-2018, 05:49 PM
Ridgey
Ridgey's Avatar
I believe it reduces surface tension of the coolant mixture, so you have a better coolant to metal contact and therefore better heat transfer.
That was my understanding anyway...
Old 28-01-2018, 05:24 PM
martysmartie
That's right, as it's boiling point is higher, which also reduces the stress on components due to lower pressure.
Martin
L1AM_RS
22-04-2014 10:14 PM
Mr S1
18
20-04-2014 03:11 PM
SS1
23-04-2013 03:57 AM
martin willetts
45
25-02-2013 12:01 PM
t5frankie
24-02-2013 09:32 PM
Quick Reply: Waterless coolant
