Sponsored by:
Sponsored by:
Capri 2.8i engine rebuild - what to upgrade??
Old 14-11-2017, 07:32 PM
TomPengelly
Kapow!!
TomPengelly's Avatar
Default Capri 2.8i engine rebuild - what to upgrade??
So I'm going to rebuild my 2.8i motor while it's out- change all gaskets and seals, check and replace rings and shells if needed...
is it worth changing the exhaust manifolds and camshaft? Is much gained? And anything else worth doing whilst in bits?
Old 14-11-2017, 08:12 PM
I would defo change the exhaust manifolds. This will free up a few bhp.
Old 14-11-2017, 08:18 PM
Caddyshack
Caddyshack's Avatar
Is it worth exploring what they did to the 3.1?
Old 14-11-2017, 08:31 PM
charlie luciano
charlie luciano's Avatar
The 3.1 was the ESSEX v6 which was a much better engine as far as tuning was concerned, the 2.8 is the cologne v6 which has Siamese exhaust ports on each head where as the Essex had 3 branch manifolds, I had the three port heads from the boss mustang from the states on my 2.8 Granada which bolt straight on to the cologne block with no modifications needed, coupled with a four barrelled Holley carb sat on top, my Granada was carb not injection.
With the 2.8i cologne I’d defo look into changing the exhaust and manifolds to a janspeed or something like that, change the cam shaft as well, but without doing a twin turbo conversion, boring the block out or slipping laughing gas into it you can’t screw much more power out of them, I had my 2.8 in my Granada bored out to 3.1, as above cam, exhaust and carb conversion and she made around 180 bhp iirc
Caddyshack (14-11-2017)
Old 15-11-2017, 08:08 AM
Top info there Charlie.
charlie luciano (15-11-2017)
Old 15-11-2017, 06:25 PM
TomPengelly
Kapow!!
Thanks for the replies! Turns out I already have updated manifolds as they are tubular and not cast.
any suggestions on what cam kit to go for and where to buy?
Old 16-11-2017, 07:20 AM
charlie luciano
Give Burton power a shout, they do bits for a vast range of ford engines
Old 17-11-2017, 10:10 AM
TomPengelly
Kapow!!
Cheers 👍
Are there any advantages or disadvantages of upgrading the can gear to a full metal one? I'm guessing it's stronger but will it be louder?
Old 17-11-2017, 09:52 PM
Adder
Adder's Avatar
Steel timing gears are very Winey imo, I've heard you can alloy ones that are supposed to a little quieter tho !
Adder
