4x4sapphire cosworth ABS wiring
Hi
I rebuilding my 4x4 sapphire cosworth
I am retro fitting Aircon
Is there an extra hole in the bulkhead on a AC car for the wiring to go through or is doubled up with the Heated front screen wires
Also would anyone have a picture with the dash out of how all the wiring is routed
Cheers Tim
Cheers Tim
![](https://cimg9.ibsrv.net/gimg/passionford.com-vbulletin/1632x1224/dsc00091_670f6cf64d40e21b89f9ffcced467eb4a8b95ae6.jpg)
![](https://cimg0.ibsrv.net/gimg/passionford.com-vbulletin/1632x1224/dsc00092_df5bfa3b08158c84c434bed3f12cbb6c36f8faed.jpg)
![](https://cimg1.ibsrv.net/gimg/passionford.com-vbulletin/1632x1224/dsc00093_28347bec0114415cbc89e42437bd4dae74dbe11b.jpg)
Hi Three pictures of the AC conversion to the bulkhead
Holes cut in the bulkhead
Bowl spot welded in and view from under bonnet
I still have the section of the bulkhead I cut out as a template if you want it
then you will only need to obtain the metal bowl to weld in and the two mounting brackets either side of it on the engine side.
Best of luck Tim.
Sierrasideways (06-07-2017)
