7inch lsd
Old Jun 19, 2017 | 05:22 PM
eel-roy-t5r's Avatar
eel-roy-t5r
Default 7inch lsd
would it be possible to fit a lsd from a 7inch rear cossie diff into a 3.9 7inch unit ??
Old Jun 19, 2017 | 08:41 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
you need to change both the crown wheel and the pinion! the casings are the same though
Old Jun 19, 2017 | 08:58 PM
Mark V8's Avatar
Mark V8
Would be easier and cheaper to just use a diff from a 2.0 XR4x4 I would have thought.
Old Jun 19, 2017 | 09:06 PM
eel-roy-t5r
Would like to keep the lsd if poss . Is the crown wheel and pinion not got more or less teeth than the 3.6 diff
Old Jun 19, 2017 | 09:08 PM
Mark V8's Avatar
Mark V8
Don't know the tooth count, but the 2 litre DOHC XR4x4 came as standard with a 3.92:1 LSD
Old Jun 20, 2017 | 06:58 PM
eel-roy-t5r
only 1s I can find are open diffs
cheers for that info lol
Old Jun 22, 2017 | 05:15 PM
robrs2's Avatar
robrs2
You can fit the 7" cosworth lsd centre into any 7" sierra diff, open or lsd. just transfer the centre and the output flanges over to the other diff.
7 1/2" centres do not fit the 7" diff
