Mapping/fuel
Old Jun 9, 2017 | 07:11 PM
Default Mapping/fuel
I think i know the answer.
My saff was mapped using Shell Vpower but could i use say bp or tesco higher octane fuels?
Old Jun 9, 2017 | 08:11 PM
Mark Shead's Avatar
Mark Shead
Bp is a no no if the car has been mapped to the max on shell. Tesco 99 is very close to shell so it would be ok.
Mark
Old Jun 9, 2017 | 08:49 PM
costina's Avatar
costina
Live long and prosper!!
Was it a live map Glenn?
If so then yes if its a generic greens chip then in theroy it should have a safety margin in it as long as your boost is set to the chips specs.
You must be aware of det tho thats the killer.....
Old Jun 9, 2017 | 09:09 PM
Mark Shead's Avatar
Mark Shead
Completely wrong. Unless you know comp ratio and how close it is to dett that's the wrong advice to give. It's easy to blow a engine even with a generic chip.
Mark
Old Jun 10, 2017 | 07:18 AM
Yeh it was live mapped on the road.
Old Jun 10, 2017 | 09:25 AM
Loomer's Avatar
Loomer
I don't think it was live mapped Glenn, i think will got a chip from Motorsport Developments and just set the car up. I don't think he had the gear to Emulate Weber.
Old Jun 10, 2017 | 11:45 AM
turbotrev's Avatar
turbotrev
I'd only use the fuel it was mapped on on failing that something better with an even higher octane if you needed too
Cheers Paul
Old Jun 10, 2017 | 12:53 PM
martysmartie's Avatar
martysmartie
I would suspect this is the case, MSD are probably one of the only ones who can emulate Weber. He would know by the price he paid as well, as mapping would be a lot more expensive, compared to a calibration (i.e. EPROM).
Martin
Old Jun 10, 2017 | 01:08 PM
When i got the car back it still have the air/fuel tester on the car, it had the lambda sensor up the exhaust pipe.
Does higher octane fuel go off after a few weeks too. Im sure ive read this in fast ford mag??
Old Jun 10, 2017 | 02:35 PM
costina's Avatar
costina
Mark
Which is very true but how many normal folk even know what det is and or AFR......
So every generic Bayjoo chip (rip) that has been sold by burtons states only a octane rating and recomended boost pressure to set too they dont ask comp ratios etc.
So your comment is correct but very negative imo and should i have said to Glenn take it to MAD so he can fit a bit of 13mm copper tube to the intake and listen for det thru tubes and earmuffs with each supermarket fuel?
Glenn was asking a simple question.
Old Jun 10, 2017 | 02:37 PM
costina's Avatar
costina
Glenn it would of had a wideband on it to check afr mate and yes super goes off quicker than normal fuel.
But i will be told i am wrong again no doubt...
Old Jun 10, 2017 | 03:38 PM
Yeh that's what it was matey a wideband checker.
Yeh im defo sure i read higher octane fuel goes off in 2 weeks.
Old Jun 10, 2017 | 03:47 PM
gcfcos's Avatar
gcfcos
Blimey mine must be gone off fuel every time I drive it once or twice a month lol
Old Jun 10, 2017 | 07:40 PM
Yeh the same as mine and i must admit when i do drive it after been stood for a while i give it a bit kicking. Not good if the fuels off.
Old Jun 10, 2017 | 09:56 PM
gcfcos's Avatar
gcfcos
Same here lol
Old Jun 11, 2017 | 08:13 AM
Loomer's Avatar
Loomer
Martin
i can, just never had the time to use it
Old Jun 11, 2017 | 08:51 AM
Cos500's Avatar
Cos500
Where have you read that Glenn? At work I fuel aircraft and the fuel is rated to 6 months, different fuel but even after 6 months a recirculation of the fuel will liven it up again, same on Avgas 100 octane petrol although contains some lead.
Pump fuel contains around 12% ethanol nowadays as far as I'm aware too which means you'll be down 12% on your injectors
Old Jun 11, 2017 | 09:08 AM
Im sure i read it in fast ford mag when they did a feature about fuel.
Old Jun 11, 2017 | 09:27 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Modern pump fuel is shit and dose go off. If I leave my husky supermoto for a few months the fuel in the carb turns to jelly lol
Old Jun 11, 2017 | 09:53 AM
dan le moignan's Avatar
dan le moignan
Additive is used in unleaded and super unleaded which should keep it stable for approximately 6 months.
Temperature plays a big part, if stored in hot conditions you will loose some light ends out of the fuel i.e. Butane as it is low flash material etc.
Its difficult to say where you can fill up from as it depends which bulk plant supplies your area.
Just because it's a Tesco/ Shell garage etc does not mean the fuel has come from Shell direct.
At our Esso depot you see Tesco/ Morrisons/ Shell etc turn up to take fuel, as far as iam aware its only Shell that use an extra additive as they are loading.
There is a golden standard for each grade and most blend in give away for a safety margin to get the tanks on grade so each grade is usually higher in mon/Ron than the pump figure states.
Old Jun 11, 2017 | 10:17 AM
costina's Avatar
costina
I have also found this on a aston db4 at work
Old Jun 12, 2017 | 04:44 PM
cossynut2's Avatar
cossynut2
10 Year Member
Mine was mapped on Shell Optimax, always used it and I have never had any problems with it.
Old Jun 13, 2017 | 03:26 PM
R4N SS's Avatar
R4N SS
My old moonstone 3dr was live mapped by Ahmed on Shell Optimax and occassionaly I had to put Super in from other petrol stations. But I usually only just put enough in to get my journey completed and then next time im free i alway filled up with Shell.
Never had any issues and that car got driven very hard.
Defo worth having a paranoia gauge in the car - AFR gauge
Old Jun 13, 2017 | 07:58 PM
Ive got a afr gauge in mine. I will just keep on using v power. The reason i asked is ive got a tescos which is about w mile away where as the nearest shell garage is about 6 mile away.
Old Jun 13, 2017 | 09:48 PM
cossynut2's Avatar
cossynut2
10 Year Member
I have had to do the same a couple of times, I will always try to find a shell Petrol Station to get the V power. I have never had any additional gauges fitted to my Saff as I would be forever watching everything and worrying. Temperature gauge is the only one I keep an eye on.
Old Jun 13, 2017 | 11:06 PM
Adam-M's Avatar
Adam-M
See your original question wasn't quite as clear as that Glenn, Tesco 99 and shell v power have the same octane raiting so you can use either, but bp is only 97ron so you can't use it if mapped on 99.
I've seen a test done before where Tesco made a minuscule more amount of power and torque than v power so it much be good, my dad ran it for years on his Impreza and that got abused.
Old Jun 14, 2017 | 06:36 AM
costina's Avatar
costina
Most people who map cars would not map it on the limit unless asked by the customer as it will cause more problems than its worth.
Its always wise to have a safety margin.
Old Jun 14, 2017 | 06:57 AM
cossynut2's Avatar
cossynut2
10 Year Member
Its still bloody scary though when your car is on the dyno rollers!! I had to walk away as I thought the engine would go bang!!
Old Jun 14, 2017 | 07:30 AM
Joris_FRST's Avatar
Joris_FRST
Stay away from anything containing more then 5% of ethanol, (so don't put anything labelled E10 or higher in your car) if you don't use it daily, the ethanol will turn the fuel bad in about 2 weeks.
As described before, part of the fuel will become a jelly like substance, and you can't just stir it back into the fuel.
Fuel not containing ethanol if it's not gone stale, eg, less then a few months, it should mix in again.
If you really never use the car, just top it off with aspen4/aspen+ (fooking expensive though), that shit never goes stale, but worth it for storing a vehicle over winter for instance.
Old Jun 14, 2017 | 08:58 AM
yeh this is defo scary to watch lol.
I always thought tescos had a higher octane reading.
Old Jun 14, 2017 | 12:23 PM
costina's Avatar
costina
Hell yeah most of the cars from work that i take to the rollers are worth anything between 80k upto 1million so not your average car.
Mine was fun on 36psi peak boost on a T34 and in the 12's afr.
Old Jun 14, 2017 | 08:23 PM
turbotrev's Avatar
turbotrev
Does the higher octane necessarily mean it's a better quality fuel though?
I'd never put supermarket fuel in my car
Cheers Paul
Old Jun 14, 2017 | 10:43 PM
dan le moignan
Paul, super market fuel comes from the same place as the fuel for sale in shell and esso garages.
Old Jun 15, 2017 | 07:06 AM
Cos500's Avatar
Cos500
Comes from the same place but does it come from the same batch? Or even the same layer or tank? funny how the last 2 o2 sensors in my car went down just after filling up at Asda on separate occasions, only use shell/bp now
Old Jun 15, 2017 | 07:18 AM
dan le moignan
Same batch same tank, layer is irrrlevant as tanks need to be homogenous before they can be sold, layering cannot be tolerated for obvious reasons, sampling through all levels is done prior to batching to the bulk plants.
Only difference is if an additive pack is tipped in the trailer unit by the driver.
Only ever seen shell drivers do this at the bulk plant.
Old Jun 15, 2017 | 04:54 PM
Change the subject a bit but ive heard a few stories about diesel vehicles having problems due to supermarket diesel.
Apart from the cossie ive always ran my cars on supermarket petrol.
Old Jun 15, 2017 | 05:14 PM
dan le moignan
Same thing again really Glenn, The super markets don't have their own oil refineries so it all comes from the same place.
There may have been some issues when bio diesel/ fame was first introduced but not sure other than that?.
There is always a small risk of cross contamination/ water if routings are wrong at the bulk plant/ or maybe a contaminated road tanker.
