General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi, I'll get right to it, I bought an 06 st225 with a knocking engine, it has been diagnosed as piston no2 you can pretty much wiggle it about. What's the best way to remove the crank on these engines? Is it engine out job or can it be done with the engine in and out through the bottom? I'm not that clued in with st's. So I need some help from you st boys out there👍
I would look for a replacement engine, rebuilding one of theses will get expensive, also how has the piston issue been diagnosed ?
these engine have a habbit of knocking the bottom ends out not piston faults
