Have I bought a lemon?...
Old 01-06-2017, 07:38 PM
Jlroberts
Jlroberts's Avatar
Default Have I bought a lemon?...
So I had planned to build a cossie rep/track car using a Mk5 shell, was told the 1.8 silvertop was ready to run minus an injector and a battery. Picked it up for pennies really but then it came and the battery has been put into the passenger footwell and the engine was a diesel but I'm not sure if they even finished the 1.8 Zetec conversion with the amount of wires and the loom going to nothing, any help would be appreciated. 😂
Attached Thumbnails Have I bought a lemon?...-dsc_1226.jpg   Have I bought a lemon?...-dsc_1228.jpg   Have I bought a lemon?...-dsc_1230.jpg   Have I bought a lemon?...-dsc_1231.jpg
Old 01-06-2017, 08:56 PM
cossynut2
cossynut2's Avatar
You have certainly got plenty to keep you busy by the look of it! If as you say it was cheap to buy my advice would be get a decent auto-electrician to try and sort it out.Is the engine all bolted in and coupled up to a clutch and gearbox?
Old 01-06-2017, 09:33 PM
Jlroberts
Jlroberts's Avatar
Yeah the engine is all bolted in, Again it's just got a few plugs of which I'm not sure what they go to as you can see above, From what I could tell it's coupled up, I was able to depress the clutch and change gears with the engine off.
Old 02-06-2017, 07:12 AM
cossynut2
cossynut2's Avatar
Well at least that side seems ok, once the wiring is sorted out it should start up and run. When you buy an unfinished project without knowing exactly what has been done to it it can be a bit of a minefield. Hope you get it sorted out and then you can start on paintwork and interior.
Old 02-06-2017, 11:26 AM
Jlroberts
Jlroberts's Avatar
Well the seller said it was just an injector short of running, and I'm having trouble even getting one of those...but do you think it would fire with all those plugs even going to nothing.
Old 02-06-2017, 12:13 PM
gcfcos
gcfcos's Avatar
To be fair mate I'd never trust anyone who's selling a car, if all it needed was an injector then surely he would have done it and sold the car as a runner for more money? Sounds like he go in too deep and didn't know how to get it running so palmed it off. Hope u manage to get it sorted buddy
Old 02-06-2017, 03:16 PM
Jlroberts
Jlroberts's Avatar
I know what you mean mate, it's here and I expected a project but jeez I'm not even sure if they completed the engine swap and wiring. I need to find someone who can tell looms ect just from looking at them! It's got a different ecu in so I assume the loom must be changed but half of those plugs go to something that is not there? So I need to figure out what I need to put there or even if those plugs need using.
Old 02-06-2017, 04:02 PM
t230
t230's Avatar
second pic looks like fan switch plugs and crash sensor ( the three inyour hand)
Old 02-06-2017, 04:03 PM
t230
t230's Avatar
4th pic: abs , should plug straight into connector next to it
Old 02-06-2017, 06:31 PM
Jlroberts
Jlroberts's Avatar
They all go to a bracket like this on my mates car....mine doesn't seem to have it?...
Old 03-06-2017, 08:01 AM
Cos500
Cos500's Avatar
Had the same with my cossie build, bought someone else's unfinished wiring nitemare, at least yours just looks like plugs, mine had been cut about and was a real mess.
Fit whatever you need to to get it running, turn the key and see what works and go from there, if yours was a diesel there will be brackets etc missing that you will need to find from the petrol, has the fuel system been changed over?
Old 03-06-2017, 08:03 AM
Jlroberts
Jlroberts's Avatar
I think so, the tank smells like petrol, how would you be able to tell?
Old 03-06-2017, 09:10 AM
Cos500
Cos500's Avatar
Well it's not just a case of dropping a petrol engine in, if it smells like it's had or has petrol in they've probably done it, I don't know but others might but I'd be guessing the tank and pump will be different, fuel lines may run differently, ask the previous owner exactly what they did, defo not a lemon it's just a bit of work if you got it for good money, if it only needed an injector I don't understand why they wouldn't have done it but get one fitted and fire it.
If it's an unknown engine and if it's a cambelt not chain I'd have it done once the car runs and your happy all is ok.
Old 03-06-2017, 09:32 AM
Jlroberts
Jlroberts's Avatar
Yeah the only problem I'm having short of firing up the engine is getting hold of an Injector, They seem like gold dust, And I picked it up from someone who took odds and sods off of it for their MK5, An injector namely being one bit
Old 03-06-2017, 10:20 AM
Cos500
Cos500's Avatar
Must be one on eBay? even a company like eurocarparts must still supply em new, might not be a genuine one but will still do the job
Old 03-06-2017, 11:07 AM
Jlroberts
Jlroberts's Avatar
I dont suppose you would know if the injectors from a mk1 Focus 1.8 blacktop would fit this? or if I'd need that inlet ect aswell?
Old 03-06-2017, 11:16 AM
Cos500
Cos500's Avatar
I know nothing about the engine mate, somebody else might be able to
Jlroberts (03-06-2017)
Old 03-06-2017, 05:40 PM
big_wasa
big_wasa's Avatar
You have there a silvertop. They use side fed injectors. Injector seals are hard to find now.
Blacktops use end fed injectors so will not directly swap over.
There is a pic with a black box on the inner wing that looks like an edis 4 modual. Not sure about the escort but they only used these on automatic Zetec's for latter cars. If the engine has come from an auto as well and it hasnt had the crank sensor boss changed then it will never fire.
What's the code on the ecu plug ? Four letters or numbers. Often looks like a name but not on very early cars. I.e. Desk Deep jeep owls there are hundreds of them.
Old 03-06-2017, 06:00 PM
big_wasa
big_wasa's Avatar
I would agree that the just needs an injector is bollox, it's like saying it just wants re gas when the ac is shagged. I've never had one yet that I could get away with just a re gas.
I would get a set of injectors and not just one.
http://www.ebay.co.uk/itm/Ford-Monde...oAAOSwX~dWj75z
Old 03-06-2017, 06:06 PM
Jlroberts
Jlroberts's Avatar
Is that what you need mate, and also the engine and everything was swapped from an Orion.
Old 03-06-2017, 06:08 PM
Jlroberts
Jlroberts's Avatar
I'm starting to understand that now, maybe I'm in too deep with this one and it's worth weighing it in, but there's not many Mk5 shells and cars remaining so I'd feel bad about that
Old 03-06-2017, 06:51 PM
big_wasa
big_wasa's Avatar
that has got to be one of the first Zetec ecu's.
So the Edis 4 is correct to the ecu as it ran external Edis. So the crank sensor boss ect will also be correct.
It's only the 105ps version so just over 100bhp.
I wouldn't give in just yet. There may be a little info around on the net and there are lots of options to upgrade it.
Old 03-06-2017, 06:57 PM
Jlroberts
Jlroberts's Avatar
I spoke to the owner who did the engine swap and he did say he actually had it running but yeah I'd really like to get the part and check so when that arrives I will update on here.
Old 03-06-2017, 07:07 PM
Jlroberts
Jlroberts's Avatar
And why get a set of injectors, not just the one?
Old 03-06-2017, 07:10 PM
big_wasa
big_wasa's Avatar
Before you start spending, check the wiring loom around the injector plugs. The heat made the plastic sheath go hard and fall of. This gave all sorts of problems with injectors shorting.
Old 03-06-2017, 07:13 PM
big_wasa
big_wasa's Avatar
A set of four in the rail stand a better chance of being clean serviceable and matching part numbers and probably just as cheap.
http://www.ebay.co.uk/itm/Ford-Escor...4AAOSwr~lYtDbL
Old 04-06-2017, 03:03 PM
Jlroberts
Jlroberts's Avatar
She runs!!!
No exhaust after the manifold but she runs!
Old 04-06-2017, 03:11 PM
Jlroberts
Jlroberts's Avatar
Idling without help anymore, So no need to rev it or spray anything into the inlet to stop it stalling
Old 04-06-2017, 08:23 PM
big_wasa
big_wasa's Avatar
Is it still needing an injector then. Sounds like it's running on three ?
Old 04-06-2017, 08:35 PM
Cos500
Cos500's Avatar
Well done
Jlroberts (04-06-2017)
Old 04-06-2017, 09:10 PM
Jlroberts
Jlroberts's Avatar
No it has all injectors in now, It just has no exhaust after the manifold Could that explain the sound you're hearing?
Old 05-06-2017, 08:20 AM
cossynut2
cossynut2's Avatar
You must be very relieved that it runs! Once you get the exhaust sorted it will sound better and probably run smoother. How did you sort out the wiring etc to get it running?
Old 05-06-2017, 09:24 AM
Jlroberts
Jlroberts's Avatar
Very very relieved especially after buying it with the premise with those parts it would work, hope it does sound smoother with an exhaust but its proving hard to figure out if the owner cut this exhaust or it sleeves on, it literally finishes just after the manifold and a bit of downpipe.
The wiring is okayish, those plugs with nothing going to them are part of the old loom, the owner put in 2 fuel cut offs, was a nightmare figuring them out and getting it started
Old 05-06-2017, 10:23 AM
cossynut2
cossynut2's Avatar
You may have to get a custom made exhaust as you probably will find an off the shelf one may not fit.
Old 05-06-2017, 10:29 AM
Jlroberts
Jlroberts's Avatar
Why wouldn't an off the shelf one fit?
Old 05-06-2017, 10:41 AM
cossynut2
cossynut2's Avatar
Its not the original engine for that body shell so thats why you may find that an off the shelf exhaust for an orion wont fit.
Old 05-06-2017, 12:11 PM
Jlroberts
Jlroberts's Avatar
But these engines were also put in Mk5 Escorts and Xr3i's, it would be the same wouldn't it, assuming it has all the same mounting points?
Old 05-06-2017, 06:01 PM
cossynut2
cossynut2's Avatar
You may be lucky and get a system that fits straight on then. Have you had it up on a ramp to check exhaust mounting points?
Old 05-06-2017, 07:15 PM
Jlroberts
Jlroberts's Avatar
Not yet, it will be getting the brakes or exhaust done next, the servo/reservoir is completely empty of brake fluid and the brake pedal has absolutely no push in it and it's solid, I'm assuming the brakes need to be bled and new fluid
Old 05-06-2017, 08:16 PM
cossynut2
cossynut2's Avatar
If the only thing wrong with the brakes is that they need bleeding and fluid you will be lucky. Start with trying that and see how you get on. If the car has been standing for a long time there may be other problems but its a case of doing one thing at a time.
