Ford focus mk1 to headlamp facelift 1.5 help please asap
I followed the guide below got everything working bar self level motors they just dont wont to work also have three wires left over
when i plug my old lamps back in dial on drivers side dash works i even swaped the motors over from my old lamps.but still didnt work any clues????
Mk1 Wire Colours
Near Side:
Main Beam - green/black
Direction Indicator - blue/orange
Headlight Levelling - blue
Direction Indicator Earth - black
Dipped Beam - green/orange
Sidelight - orange/blue
Main Earth - black
Offside:
Main Beam - green/orange
Headlight Levelling - blue/red
Dipped Beam - green/white
Sidelight - orange/green
Main Earth - black
Mk1.5 Wire Colours
Near Side:
Direction Indicator Earth - black/Yellow
Main Earth - black
Offside:
Direction Indicator Earth - black/Blue
Main Earth - black
As you can see most of the colours are the same, the only thing you have to watch is the orange and green wires, i wired mine up and the sidelight on the drivers side wouldnt work, the fuse was fine, everything, there is 2 orange and white wires on the drivers side headlight, one for sidelight, one for main beam, id got them wrong way round switched them over and it worked fine.
All the wires are the same so its just match the colours up, apart from the indicator wires they are different on each side, but just follow the guide as above and match the colours to the corresponding function on the headlights.
I just spade connected mine, depends how fussy you are with your car, if you do decide to spade/bullet connect them id put some vaseline on the connections and then insulation tape them up
