Oil leak from intercooler on Connect
Hi all, I had an oil leak from the right hand intercooler pipe. The plastic pipe running under the intercooler pipe had rubbed through and holed it. As the oil leaked over the engine the leak looked bad but was easily sorted with a replacement however, the plastic pipe underneath is rubbing on it. As this was the cause of the leak in the first place, can anyone explain how the plastic is routed so as not to rub. See pics attached as reference.
