Big disc upgrade for 2wd Cosworth !!!
Old 05-04-2017, 01:11 PM
GINGExR2 T
GINGExR2 T's Avatar
Default Big disc upgrade for 2wd Cosworth !!!
Anyone know if there is a bigger disc upgrade for a 2wd but using the standard callipers!!!!!
Ginger
Old 05-04-2017, 09:09 PM
james kiely
james kiely's Avatar
im sure i have a set of discs/bells and brackets that were made by hispec for this application ginger .
have a look on burtons website
Old 05-04-2017, 09:46 PM
cossynut2
cossynut2's Avatar
Ginger
Can I ask if you are looking at getting more braking power? If you are my advice would be to go for a big brake kit including new 4 or 6 pot calipers.It will be a big improvement over the standard set up and well worth the outlay.
I am not sure you will gain much by fitting bigger discs with the standard calipers.
This is what I have on my 2wd Saff and they work very well.Mine are the Hi-Spec kit but there are lots of different set-ups from various companies.
Old 06-04-2017, 10:26 AM
R4N SS
R4N SS's Avatar
standard 2wd calipers can be made to fit 325mm discs or was it 300mm cant quite remember now but you will need to space the calipers to suit. I do have the spacers buried somewhere in my garage but should be quite easy to remake as its just a small cylinder type of tube
Old 06-04-2017, 11:00 AM
Marc sierra
Marc sierra's Avatar
Why would you want to keep the standard calipers? They are very heavy as they are cast iron and in my experience the pistons also seize quite quickly on them. If it was me I'd go for a nice aluminium Brembo caliper, like the ones from a BMW E38.
Old 06-04-2017, 12:31 PM
R4N SS
R4N SS's Avatar
So would I. I have Focus RS Brakes on my Saph but am having to keep to standard brakes on the 3dr as the wheels wont fit otherwise. If I decide to change the wheels then the brakes will be upgraded for Focus RS brakes
Old 06-04-2017, 01:31 PM
davidfox280585
davidfox280585's Avatar
i have as set of focus rs calipers and discs with diy adapter brackets to fit 2wd cosworth for sale
Old 06-04-2017, 03:20 PM
GINGExR2 T
GINGExR2 T's Avatar
Cheers for the replies, The only reason I was thinking of using the original callipers is due to the fact I already have them and if there was a simple bigger bolt on disc upgrade it's easy.
I'm trying to keep a factory spec disc for ease of replacements, cost and keeping it simple. they are going on my convert Escort RS Turbo, not going full race spec car or anything like that so wanted an upgrade to match the rear 4x4 brakes I already have.
I do like the look of the E38 callipers and Focus RS disc, the callipers do look very similar to a set of Porsche Brembo's I have already.
Cheers again.
Old 06-04-2017, 04:01 PM
ircossie76
ircossie76's Avatar
Bmw callipers with the focus rs disc's for me, big improvement on the standards.
Old 06-04-2017, 04:50 PM
tjRS500
tjRS500's Avatar
What upgrades have people done whilst retaining a 15" rim?
Old 06-04-2017, 06:44 PM
Mark V8
Mark V8's Avatar
Reyland do a 295mm kit with AP 4 pots for standard 15" wheels
http://www.reyland.co.uk/2wd-front-kits/
Old 06-04-2017, 09:54 PM
R4N SS
R4N SS's Avatar
On my 400bhp Moonstone 3dr I had standard sized but uprated discs with fereodo ds2500 pads - it worked fine but it did sometimes get a little scary after 100mph and then having to stomp on the anchors
Old 07-04-2017, 09:22 AM
1374lee
1374lee's Avatar
Problem is they are mega money for what they are, was it £1500?
Thanks. Lee.
Old 07-04-2017, 01:06 PM
R4N SS
R4N SS's Avatar
Thanks. Lee.
Not worth 1500 quid
you can get a proper brake setup for that
R4N SS
R4N SS's Avatar
Cheapest way of doing this would be 300mm discs from a focus ST and 4x4 front calipers - this should then fit behind a 15" wheel - i know the RS7 spokes fit over these
Old 07-04-2017, 01:14 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Originally Posted by R4N SS
Not worth 1500 quid
Really? To fit inside a std wheel??
Old 07-04-2017, 03:05 PM
R4N SS
R4N SS's Avatar
Personally if i was to spend 1500 on brakes i would go for the biggest i can get which would obviously mean a wheel change hence why my saph runs Hocks now.
Old 07-04-2017, 03:26 PM
Martin-Hadland
That's my point, that kit is specifically designed as a max fit for the standard wheel. There are plenty of Cosworth owners that wish to retain the OE wheel, same goes for the RS Turbo guys.
R4N SS (08-04-2017)
Old 07-04-2017, 04:27 PM
lee2cossies
lee2cossies's Avatar
I used a pair of mg tf ap 4 pots with st170 300mm discs to fit behind a 15" wheel on my capri, calipers are around £200 a pair discs from £50 a pair depending which ones u want, brackets need to be made but nothing that's hard, pretty decent set up for not much money.
Old 07-04-2017, 06:23 PM
wildheart
wildheart's Avatar
I've been running standard calipers with the Hi Spec 325mm Kit on for past 12 years and done loads of trackdays and they've been fine.
Old 07-04-2017, 07:53 PM
james kiely
is that under a 15 inch standard wheel mate ?
Old 07-04-2017, 08:54 PM
GINGExR2 T
GINGExR2 T's Avatar
Is it this kit mate
http://www.bigbrakes4u.co.uk/index.p...productId=3966
It says standard callipers but the discs are 30mm, the calliper gap is only 26.5mm
Ginger
Old 07-04-2017, 08:58 PM
wildheart
wildheart's Avatar
No, it's under 17's
Old 07-04-2017, 09:00 PM
wildheart
wildheart's Avatar
Is it this kit mate
Ginger
No,
Mine have alloy bells.
Got them through Mike Rainbird back in the day!
Old 08-04-2017, 07:13 AM
GINGExR2 T
GINGExR2 T's Avatar
No,
That kit does have belled discs, pic is not the correct discs. Have you got any pics of yours fitted.
Did you have to modify the callipers in anyway or are the disc still factory 24mm thick???
Ginger
Old 08-04-2017, 03:19 PM
R4N SS
R4N SS's Avatar
Ginger
You have to add the little spacers supplied in the kit mate so probably have to split the calipers first then add the spacers
Old 09-04-2017, 08:58 AM
Adam-M
Adam-M's Avatar
What about the copper pipes that link both sides of the calliper together won't you have to extend them if you space the callipers apart?
Old 09-04-2017, 11:03 AM
Mad_Mat
New Owner
Mad_Mat's Avatar
liking the sound of this setup. Could you share a picture?
What pads have you been using?
Old 10-04-2017, 02:49 PM
GINGExR2 T
GINGExR2 T's Avatar
Does anywhere sell the calliper spacers to widen the calliper gap???
Ginger
Old 11-04-2017, 12:28 PM
R4N SS
R4N SS's Avatar
Ginger
Hi mate, i think i have a set in my garage somewhere - will need to look for them though
Old 11-04-2017, 07:13 PM
3doorcozmess
3doorcozmess's Avatar
how much does this conversion cost
Old 12-04-2017, 03:10 PM
1374lee
1374lee's Avatar
This is from capri sport he normally has the calipers to but cannot see them on his site at the minute.
Here's the discs and spacers etc.No calipers in this listing.
http://www.ebay.co.uk/itm/Cosworth-2...oAAOSw~uhUnwDV
Brackets only.
http://www.ebay.co.uk/itm/Cosworth-2...IAAMXQWuRRAtGj
Thanks. Lee.
Old 16-04-2017, 05:22 PM
Adam-M
Adam-M's Avatar
I'm surprised you haven't mentioned these martin.....
Old 16-04-2017, 05:28 PM
Adam-M
Adam-M's Avatar
Martin I'm saving for an Ap 6 pot kit and always wondered why you have to pay extra for a red calliper? It's not just you who does this, you can buy wheels in different colours free of charge but AP's are extra?
Just curious.
Mark RS
13-01-2016 06:56 PM
Fudgey
11
26-05-2009 10:47 PM
BlackSaff
19-05-2009 08:28 PM
thelynx
17-05-2006 08:58 AM
Quick Reply: Big disc upgrade for 2wd Cosworth !!!
