Cosworth small end replacement ???
Question for engine people
Just had my bottom end back from the machine shop, going with over sized pistons as there was a small mark in the one bored that had to be machined out. so whilst it was being done I decide to have new small ends fitted.
I know they had to be reamed out so was done.
Question is, should I have a small amount of play between the gudging pin and the small end bearing as mine has.
Just seems a bit odd to me,
Any info helpful
Ginger
Any info helpful
Ginger
Any info helpful
Ginger
Any info helpful
Ginger
Try dunking the gudgeon pin in fresh engine oil then install in the small end and then see if there is any play.
If you fit them together dry then yes you will get play as the clearance is for oil to sit in.
