possible ABS problem with the 3dr
Old Apr 10, 2005 | 04:35 PM
B11GNS's Avatar
B11GNS
Default possible ABS problem with the 3dr
when i'm driving normally its fine, its just when i come down to almost stopped the pedal sort of vibrates and buzzes and then goes hard, the brakes still seem to work ok although when the pedal goes hard you only touch the pedal and you go through the screen .
Then when you speed up it goes away.
Any help would be appreciated
Old Apr 10, 2005 | 04:38 PM
RSKim's Avatar
RSKim
Mine does that all the time - fook knows why - I just ignore it pmsl
Old Apr 10, 2005 | 04:50 PM
Deano's Avatar
Deano
A case of if you dont admit theres a problem then there isnt one
Old Apr 10, 2005 | 06:17 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i had the same problem. changed front sensors and cured it.
Old Apr 10, 2005 | 06:18 PM
B11GNS's Avatar
B11GNS
I'd rather get my sorted really, not keen on there being a problem of any sort with the brakes, anyone any idea?
Old Apr 10, 2005 | 06:24 PM
RSKim's Avatar
RSKim
lol @ Deano...well you know.......brakes still work - if it aint broke and all that...
Let us know if you find out what it is mate, if you don't mind that is
Old Apr 10, 2005 | 06:40 PM
B11GNS's Avatar
B11GNS
It sounds like something to do with the front wheel sensors as Nick has pointed out which does make a bit of sense as i've just had the sensors out to do the wheel bearings so i am going to check that they have gone back in ok, the manual does acctually say that you should use a new o-ring and lots of grease when replacing the sensors which i didn't do so will have them out again, if theres no difference then i shall replace them.
Sierrasideways
Oct 8, 2015 06:37 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
155lee
Sep 23, 2015 01:27 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
