17 reg Focus ST3 noise problem
Hi all,
This is my first post in the forum so please be nice!
I picked up a brand new Focus ST3 on March 11, by March 13 it was making a noise, tried to not panic and thought it wasn't anything to worry about but the noise has got louder. It's like a intermittent crackle/rattle.
It stops when the air con and/or heating is on and only happens after i've driven the car so not from cold.
I had an mechanic listen to it and he thinks there is a fault with the air con clutch compressor pulley or bearing. Today I've taken it to Ford and they cannot work out what is wrong with it, they have acknowledged there is an issue but they do not know what.
They have eliminated the air con compressor and said they have checked everything, and it may be that the engine needs to be dropped out and the drive belt/chain checked!!
I've owned the car 13 days now and I'm distraught, this is my first new car and i just thought it was hopefully something loose, not that the engine would need to come out!
Has anyone else had this issue or got any ideas?
I've got a video but it's not uploading so I will continue to try and add this to my post.
thanks,
Vicki
thanks,
Vicki
It's at Ford now but they are saying about dropping the engine out, I'm not happy! i just wondered if anyone had a similar noise problem so could shed some light on what it is.
thanks,
Vicki
thanks,
Vicki
The noise could literally be anything - don't be alarmed by the engine coming out - it will be for access
Please don't accept it back until you are happy with it.
Its up to Ford to sort out what ever the problem is, it does seem unusual on a brand new car to have a problem so soon but let them have it and only accept it back when you are 100% happy with it.
