DIY oven - fao: electricians?
I'm looking to make an oven with an internal size of 500mm deep x 500mm wide x 500mm high.
I'm hoping to be able to use the heating element/thermostat from a fan assisted oven.
The oven body would be made from sheet stainless, what would I use to insulate the oven? Also, how does the element work and would be able to use an element from a smaller oven.
I need a constant 200 c for 15 mins at a time.
could use insulation wool or brick to insulate it
a heating element is just a coil of wire his give off energy when current is applied
dont see why you couldnt use a heating element from a small oven
what you trying to heat up?
I'd go down the local council tip and get an old oven,pull it to bits and see how it's put together. Get a couple and salvage the insulation etc from them. No,i'm not a gipsy.
Good results but I need to perfect curing.
I'm planning on a two stage curing process, Firstly give the coat 2 mins under a IR lamp to settle any dust and aid surface flow, then place into a convection oven and cure completley.
van_dogg_pavvy
03-03-2016 09:30 AM
rog
04-09-2015 07:24 AM
