Tool advice
Old Jun 5, 2016 | 09:23 AM
TrevCos's Avatar
TrevCos
Default Tool advice
Hi guys, anyone know what sort of tool I need to fit the split rings to hold the boots on the track control arms on the Cossie. Some people supply cable ties with them which are pretty useless so I want to put the proper metal rings on but I can't open them enough to fit them.
Is it some of those split ring pliers that jewellers use that I need? There doesn't seem to be a tool on E-BAY in the car related tools area.
Old Jun 5, 2016 | 10:21 AM
stevieturbo's Avatar
stevieturbo
C**t
Like CV boot wire crimp things ?
http://www.justoffbase.co.uk/CVJ-Boo...-Sealey-VS1633
Old Jun 5, 2016 | 10:25 AM
TrevCos's Avatar
TrevCos
Originally Posted by stevieturbo
No, I've got some of those. You know on track control arms you have the joint on the end with the rubber boot on that goes into the bottom of the hub, that boot is usually held on by a split ring, like you get on keyrings. I need a tool to be able to open those out so I can get them on.
Old Jun 5, 2016 | 10:29 AM
stevieturbo
C**t
Ahh right, not sure on that, never had to change them.
Will they not just un-pick and pull off with a small pick or something ? They would be more springy than a key ring ?
Old Jun 5, 2016 | 10:32 AM
TrevCos's Avatar
TrevCos
I can get the old ones off but not the new ones on.
Old Jun 5, 2016 | 10:54 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Just normal punchers clamp them clips up fine you don't need a special tool
Old Jun 5, 2016 | 10:56 AM
ajamesc's Avatar
ajamesc
Like these on eBay 300938315266
Old Jun 5, 2016 | 11:16 AM
TrevCos's Avatar
TrevCos
It's not that I'm after though, it's the little track rod end style boots that I need to secure (although it's the track control arm ones).
Old Jun 5, 2016 | 11:20 AM
TrevCos's Avatar
TrevCos
Its a tool to put these ring on I'm after.
Old Jun 5, 2016 | 11:26 AM
gcfcos's Avatar
gcfcos
I've been a mechanic for over 20 years and I didn't know there was a tool for them lol, In fact we use wire instead of the supplied cable ties and twist it tight then cut off the end. Would some small circlip pliers work? Sorry couldn't be more help
Old Jun 5, 2016 | 11:27 AM
TrevCos's Avatar
TrevCos
Originally Posted by gcfcos
I've been a mechanic for over 20 years and I didn't know there was a tool for them lol, In fact we use wire instead of the supplied cable ties and twist it tight then cut off the end. Sorry couldn't be more help
Maybe that's the way I should go. How do they put them on in the first place I wonder?
Old Jun 5, 2016 | 12:00 PM
Caddyshack's Avatar
Caddyshack
I think they wind on like a cork screw, that's how I did mine
Old Jun 5, 2016 | 12:03 PM
Moonstone Mart's Avatar
Moonstone Mart
I can't quite tell what the ring is supposed to look like but i have these at work for driveshaft/gearbox circlips split rings. Ebay item no 171137095203.
Old Jun 5, 2016 | 12:31 PM
ajamesc's Avatar
ajamesc
I thought you was talking about the metal clips on the other end like you get on cv boots
Old Jun 5, 2016 | 01:29 PM
tosh's Avatar
tosh
I done this about 25yrs ago but since then I have just changed the complete thing, and from memory I'm sure I used a tapered piece of plastic tube (don't ask me where I got it!) you then slide it down from the thin end and it expands the clip, then you push it off the end and onto the rubber boot.
Old Jun 5, 2016 | 01:30 PM
gcfcos's Avatar
gcfcos
I think someone told me on a lemforder suspension course we went on that they make thousands at a time and everything is done in a machine so I imagine the machine just clamps the ring on. With the twisted wire we use we haven't had one pop off as of yet. Hope u Manage to get it sorted mate
Old Jun 5, 2016 | 01:41 PM
Caddyshack's Avatar
Caddyshack
That's a good idea. A joiner may be able to turn one up in wood or similar in a metal shop
Old Jun 5, 2016 | 02:11 PM
TrevCos's Avatar
TrevCos
Now there's an idea. Perhaps a strong funnel cut up to the right size.
Old Jun 5, 2016 | 02:13 PM
TrevCos's Avatar
TrevCos
Some great suggestions here, thanks guys.
Old Jun 5, 2016 | 05:22 PM
tosh's Avatar
tosh
It obviously also needs to be hollow with the insternal diameter just large enough to fit over the widest part of th boot.
Old Jun 6, 2016 | 06:44 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Ahh. What I use is two cut lengths of 3/16 brake pipe, about 2-3inches long. Put one over each of the open ends of the keyring type clip. Push both together and the clip expands allowing you to fit it over the ball joint boot. Release and hey presto!
Old Jun 6, 2016 | 06:59 PM
cozzy jeff's Avatar
cozzy jeff
today's top tip
Old Jun 6, 2016 | 07:04 PM
studabear's Avatar
studabear
Yeah as above a couple of bits of brake pipe, thats what we were supplied with all our boots
Old Jun 6, 2016 | 08:32 PM
TrevCos's Avatar
TrevCos
Now that's a brilliant tip, thanks mate. There's always someone who knows!
Old Jun 7, 2016 | 02:54 AM
Cosnada's Avatar
Cosnada
I'm going to get some stick here.....
When I was a lad I used to help the local farmers with lambing. Part of this was to castrate them. To do this a small rubber band was stretched over its bollocks and released. To do this a tool called an elastrator was used. It's either 3 or 4 prongs that open up with a small Ridge so the ring doesn't fly off.
I had to do the front ball joints on a vw transporter and I bought one of these tools to do the clips and it worked perfectly. I did think about electricians cable label stretchers too but the elastrator has a little groove.
http://m.ebay.co.uk/itm/ELASTRATOR-C...295?nav=SEARCH
timsrs
11
May 21, 2016 04:48 PM
ByronG
May 17, 2016 01:42 PM
Caddyshack
May 15, 2016 09:00 PM
gcfcos
May 14, 2016 06:02 AM
