Help please.... ECT reading high voltage
Old Mar 15, 2016 | 10:17 AM
fordsteve77's Avatar
fordsteve77
Default Help please.... ECT reading high voltage
Escort 1.8 Zetec 16v 1997
Been having a lot of problems trying to sort my slow rad fan speed working
Its a 1 fan 2 speed
low speed for when engine getting hot
high speed A/C
High speed works no problem
changed the 3 sensor switches
ECT engine coolant temp
ETS engine temp sensor/reader
Rad switch
also have changed to big green relay behind the battery
Took it to a snap on reader:
It read the ECT temp going up/down with high speed on off
it read ECT as have high volts ....????
stuck now...?
Old Mar 15, 2016 | 01:19 PM
stevieturbo's Avatar
stevieturbo
C**t
What determines the speed ?
How many wires to to the fan ? Is there one of those shitty resistor packs at the fan ?
Old Mar 15, 2016 | 01:23 PM
fordsteve77
4 wires to fan switch
then
2 wires to fan
2 wires to the resistor in picture
Attached Thumbnails Help please.... ECT reading high voltage-20160129_113932.jpg
Old Mar 15, 2016 | 01:24 PM
fordsteve77
I swapped that out for another one from a KA still same problem
fordsteve77
when I check resistance I set reader to 20k
and reading on that above
is
0.00 or 0.0
Old Mar 15, 2016 | 01:25 PM
fordsteve77
both the original and replacement were same reading
J690Turbo
Ford Escort RS Cosworth
17
Jun 8, 2024 12:46 PM
monte029
286
May 19, 2019 04:29 PM
Rs(555)
Feb 28, 2016 08:31 PM
Maunduz
Ford Focus ST
Feb 23, 2016 06:31 PM
Phil_rs1800
Feb 16, 2016 07:18 PM
