Acceptable battery drain?????????
How many volts should the car be using when switched off?????
i.e. if you disconnect the earth leads and put a multimeter in between the leads and the neg terminal my car has a difference of 0.24 volts...
(batt voltage minus the other reading!!)
is this too much???
is this too much???
07-10-2015 01:56 PM
