Does anyone have or do a wiring diagram for
Old 07-04-2005, 10:30 AM
Alps Pacino
Alps Pacino's Avatar
Default Does anyone have or do a wiring diagram for
Fitting Cossie managment on a series1. Cant see it being that hard to do if someone has a wiring diagram.
Old 07-04-2005, 10:37 AM
Ryan
Ryan's Avatar
A Cossy ECU & loom only require 3 wire to run:
Permanant Live
Ignition Live
Pump Trigger
The car will run with just those connected.
Feeds off the cossy loom which need to be wired into a s1 loom are:
Rev Counter = Green
Water Temp Sensor = Brown\White
Old 07-04-2005, 01:43 PM
Alps Pacino
Rev Counter = Green
_________________
You mean the green wire and the brown/white is on the cossie loom or the other way round. Which wires do these need connecting to ie green-?
Old 07-04-2005, 01:52 PM
jon@work
jon@work's Avatar
the green on the cossie loom needs to be connected to the wire that feeds your rev counter - check for continuity between one of your original ignition coil wires and the multiplug on the back of your clocks to identify the right wire.
do similarly for the brown/white on the cossie loom that connects into the back of your clocks to feed the temp gauge.
Old 07-04-2005, 01:56 PM
Alps Pacino
Souds pretty easy i think i have a manual with all the wiring diagrams for a s1 somewhere. Sounds a LOT easier than i first thought.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
THE RADMAN
19-09-2015 12:57 PM
Quick Reply: Does anyone have or do a wiring diagram for
