skimming cosworth pistons
I have a 7,2c/r cosworth engine and want to raise the c/r so i was thinking to use 133,5mm rods and skim pistons 5mm.
They are genuine cosworth pistons. Would this be possible to skim them that much and what would the c/r be?
How much wall thickness will be left at the top of the piston once 5mm has been taken off? I doubt there will be much left.
Presumably you have the pistons there to measure and see how they are constructed ? SO you would be best placed to decide.
But you can be sure removing 5mm from the crown of almost any piston is going to leave minimal top ring land, which on a boosted setup is never good.
Out of interest why do you want to raise it?
Cheers Paul
Cheers Paul
turbotrev (17-12-2015)
Would it matter if it wasn't on that fuel?
Cheers Paul
Cheers Paul
Interesting, nice one
Cheers Paul
Cheers Paul
Yes, i want more c/r for more response and power @ the same boost.
Running a KMS ecu so closed loop fueling and good ignition control.
I will buy new pistons because 5mm will be way to much to skim + valve pockets.
Just was thinking to save some good pistons.
Any other ideas to raise it, would like to be around 8/1.
How does a near standard compression ratio give you more response when compared to the lower ratio you have now?
Is it in regards to the timing as Mark mentioned?
Cheers Paul
Cheers Paul
Mark
Mark
Can you not control the back pressure with different sized exhaust wheels/housings?
Cheers Paul
T4 twin scroll .92 on the 7064.
I also doing an engine with 6758 wich also is t4 twin scroll .80
Will be on the dyno soon so will post results later.
I did a gt3071 i while ago on a .63 housing and made 432bhp@1.5 bar.
minky
30-01-2016 11:23 PM
