Help transit connect
Old Nov 13, 2015 | 02:48 PM
andy130's Avatar
andy130
Default Help transit connect
hi have transit connect tdci that is not feeding fuel to the common rail an instead is just sending it back to the tank, changed the pump an its still do same thing an also changed the 3x fuel sensors an still no go, anyone help me out as a stuck for van for work
Old Nov 13, 2015 | 03:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
glenn?
Old Nov 13, 2015 | 04:05 PM
Have you got rid of all the air out of the system. These engines can be a nightmare to start. Have you changed the fuel filter as well. What i do at work is i use a car petrol fuel pump and put it on the fuel filter and the pipe to the engine and use that to suck the diesel through.
Old Nov 13, 2015 | 05:51 PM
gcfcos's Avatar
gcfcos
Yeah that's what we do, works a treat. They can be a nightmare after just changing the fuel filters can't they mate
Old Nov 13, 2015 | 07:06 PM
andy130's Avatar
andy130
but am getting fuel at the return pipe mate, its just not feeding the common rail tho?
Old Nov 13, 2015 | 08:00 PM
So your not getting fuel from the pump to the rail??
Old Nov 13, 2015 | 08:38 PM
andy130's Avatar
andy130
yeah glenn, doing the same as the pump i took of
Old Nov 14, 2015 | 08:43 AM
Thats very strange you would if thought it was the pump.
They dont need timing up either so its not that. I take it its a new pump??
Old Nov 14, 2015 | 06:19 PM
DangerousBryan's Avatar
DangerousBryan
Have you tried gravity feeding the pump? And have you checked the leak back from the injectors?
Old Nov 14, 2015 | 06:54 PM
andy130's Avatar
andy130
it was the fuse for the PRV thanks for the help tho guys
Old Nov 14, 2015 | 07:02 PM
DangerousBryan
Bummer,oh well,at least you've found it.
Old Nov 15, 2015 | 10:07 AM
Yeehhhhhhhhhhhh. Thank fook for that lol.
g350 aar
Aug 20, 2020 03:59 PM
truffleshuffle
Nov 13, 2015 11:19 PM
axxeman
Nov 13, 2015 12:44 PM
MattSPL
Nov 11, 2015 05:10 PM
bevog
Nov 11, 2015 05:38 AM
