4x4 cossie sterring rack same as xr4x4???????
Originally Posted by SPADGE
Originally Posted by Rs Gus
spadge its for my mate ill tell him
Originally Posted by Jimboxr4x4
Yes, believe your right Johnny same racks but cossies have slightly less turns lock to lock (think its 2.4 instead of 2.9).
Originally Posted by markk
there are shaft differances m8 on the pinion just be careful that the length is the same
you only had to ask
unlike me - who asked about showers and sinks 8 weeks ago
you only had to ask
and yes i did forget
you only had to ask
you only had to ask
you only had to ask
you only had to ask
you only had to ask
you only had to ask
When I needed an Escos rack I found there was 2 different splines on the steering shaft, fine and course.
I was told the one I had was the same as a Granada.
Don't think they are Cosworth specific just 4x4 or 2wd
Originally Posted by JohnnyB
I think its 2.5, but not sure
The reason why the 4x4 rack is differant to a 2wd one is the TCA are shorter on a 4x4.
so all 4x4 racks will fit all 4x4's
4x4 and 2wd racks are not the same
for a start the mounting points on a 2wd are behind the rack and on a 4x4 there infront of the rack
cozzy 4x4 tcas are same lenth as 2wd tcas
4x4 cozzy racks have a thicker spline and shorter than a 4x4 v6 rack
Brom, I know 2wd and 4wd racks are differant, but all I remember try to put a 4x4 TCA's on a 2wd and it had major toe in and I cannot, be ajusted.
All I can say what I have found
Russ Payne
25-09-2015 08:29 PM
