Map sensor Voltages
Old Aug 29, 2015 | 08:30 PM
Tim Wharton's Avatar
Tim Wharton
Default Map sensor Voltages
I've just rebuilt my cosworth engine and have changed to 803 injectors , 3 bar map sensor and remapped ECU chip to suit.
I am using non-genuine map sensor ie not (magnetti Marelli) as I have read horror story's about incorrect fueling damaging engines I wish to test all my sensors are giving the correct outputs.
I have a breakout box and Y lead so can access all the output voltages from sensors to the ECU.
Can anyone give me a chart of voltage against pressure for a 3 bar
Cheers Tim
Old Aug 29, 2015 | 08:40 PM
1300gt's Avatar
1300gt
If your using a BOB make sure you check it for voltage drop on live and earth sides when it's all connected up as you need to see battery voltage or your readings will be off!
I've not here'd that about the genuine map sensor?
Old Aug 29, 2015 | 09:22 PM
fraser9764's Avatar
fraser9764
Old Aug 29, 2015 | 09:24 PM
fraser9764's Avatar
fraser9764
You really need some form of pressure/vacuum source to test the sensor calibration. A mitivac is ideal
Like this
http://www.ebay.co.uk/itm/Mityvac-MV...item48787e1923
Handy to have in the garage to be honest. Good for bleeding brakes etc. too.
Old Aug 30, 2015 | 05:46 PM
Tim Wharton
Hi Fraser
Many thanks for the map sensor voltage chart
I have got a good quality workshop boost gauge and I use my cooling system pressure tester to give pressure.
I may make a permanent link to the relevant ECU wire so I can check it on the road with the boost gauge connected and a Mate taking readings
Cheers Tim
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
