Sponsored by:
Sponsored by:
passionbmw peeps! dpf removal ***MSD***
Old 28-06-2015, 06:47 AM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
Default passionbmw peeps! dpf removal ***MSD***
alrighty, i bought my 330d a little bit back and now i'm getting dpf filter warning on the screen, already remapped and stats been done(holds high 80's down the Mway).
so who to go to for the delete, i'm not replacing it if it won't regen.
i've taken it for a blast and it's kicked out loads of crap, but still seems down on power.
msd for mapping it out as per remap, but would stripping it out and welding a pipe through be better or just getting a delete pipe.
bit disappointed to be fair as it does get a fair amount of long runs, just not in the last two weeks.
Old 28-06-2015, 07:10 AM
studabear
studabear's Avatar
Be better if it looks like it is still there with regards to the mot, unless your usual tester isn't arsed.
Old 28-06-2015, 11:07 AM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i was thinking of just cutting the casing over, ripping guts out and fitting a smooth pipe through it.
Old 28-06-2015, 11:34 AM
oldford
oldford's Avatar
Without changes to the electronics ripping out the guts of a DPF will result in fault codes and a lit engine malfunction lamp.
Old 28-06-2015, 01:22 PM
Nick.W
Nick.W's Avatar
I had my DPF removed and coded out by a company called Top Gear Motorsport on my E92 330d.
Was really happy with the work that they did, basically gutted the DPF and re welded down the original welds so with a bit of road grime you probably wouldn't know if you looked underneath. I would recommend them.
http://www.topgear.co.uk/mapping
Old 28-06-2015, 08:22 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
Yup, will go back to msd for that.
Old 01-07-2015, 12:43 AM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
so i'm thinking of knocking out internals and welding lid back on dpf.
this will be a long job due to removing dpf is a pain so i read.
questions:
1, will i be able to drive to msd for it to be written out of coding?
2, anything else needed to be done in regards to mapping as it has already had map changed.
Old 01-07-2015, 10:34 AM
RobbieBambino
RobbieBambino's Avatar
Im not sure on the dpf delete side of it but i will second what you have said about the pain to remove! Is it e92 330d? Its a complete and utter ball ache matey not much room in there
Old 01-07-2015, 10:50 AM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
It's an e90, looks tight at a glance.
I even thought of drilling from the bottom to break it up.
Fabricating an off centre drill bit so it will mangle the ceramic with ease, whilst flushing with air from turbo.
Just thoughts, but when i get some evening I'll crack on.
Old 01-07-2015, 09:48 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
had a quick look, hmmmm...
will be a painful job just getting round, may just attack the dpf porcelain from the pipe coming out of it, will be messy but will clear the dust quickly i'm sure.
Old 02-07-2015, 10:49 AM
Rick
Rick's Avatar
When you remove the DPF, you will get a DPF low efficiency code and MIL which will eventually trigger limp mode. The car is still drive-able though.
Rick
Old 02-07-2015, 12:58 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
Cheers for the heads up
Old 12-07-2015, 08:56 PM
stu21t
stu21t's Avatar
I've got to have this done to mine as my dpf is dead.
My question is
Should I remove the egr valve and have that mapped out at the same time?
What's the down side to removing the egr?
Old 12-07-2015, 10:34 PM
slammedorion
slammedorion's Avatar
My question is
No downsides to blanking and mapping egr out...
Only plus sides...
Less coked up inlet, no stupid egr fault lights, not replacing or cleaning egr every 5 minutes...
It's all win win...
Get rid of it...
Old 12-07-2015, 11:42 PM
Carlos-Titx
Carlos-Titx's Avatar
My question is
MSD force closed (I think that's the term) my egr and runs a bit smoother .
Other than that it's all long term benefits with all clogging up with crap. And bad running.
Although I still need to remove the egr and clean it to make sure it is closed fully.
Old 13-07-2015, 11:33 AM
stu21t
stu21t's Avatar
I was thinking of buying a replacement pipe to totally remove it,
http://pages.ebay.com/link/?nav=item.view&alt=web&id=151553660506&globalID=EB AY-GB
Old 14-07-2015, 11:00 AM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i haven't had mine done yet, i took it for a drive, stopping when fault lit up, killed ignition and waited five mins, run again and it cleared up nicely.
i would get dpf removed, egr coded out and then it'll run nicer and cleaner, well in terms of power and smoothness anyway.
boeb
09-01-2020 05:11 AM
Orion_Gav
29-09-2015 04:50 PM
Quick Reply: passionbmw peeps! dpf removal ***MSD***
