Fiesta MK3 XR2i camshaft
CrazyRx
Hi there im new here ,i want to buythe kent cam CVH33K for my ford fiesta xr2i 1991 efi , approximately 20bhp increase they say
Applications Competition Power Band 2500 - 7000 Cam Lift(mm) 7.36mm Inlet/7.24mm Exhaust Valve Lift(mm) 12.14mm Inlet/11.63mm Exhaust Duration 290 Deg Inlet/ 285 Deg Exhaust Timing 36/74 72/33
now the question is :''have someone put this cam on his car?'' i know if i put this cam the idle will be irregular .
CrazyRx
I',ve contacted the piper sales for a similar camshaft like this and they responded with this message:
The do camshaft for Pinto engine not the CVH. We do not make a cam for the CVH engine ... can't believe...
If i put this kent probably i need to change the springs and you should fit new followers with the camshaft. all the kit 370 phound...
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Steve Escos
01-10-2015 06:57 AM
