Help Fitting Grey's Needed...
Old Apr 3, 2005 | 04:01 PM
sirmark's Avatar
sirmark
Default Help Fitting Grey's Needed...
Got to fit a set of grey injectors to my car this weekend, can someone
tell me how they fit them. I know someone had a picture of an
injector with the fitting kit on it, any chance someone can post that up?
Injectors have a blue shroud on the end (not I don't mean the covers)....
Old Apr 3, 2005 | 04:06 PM
gurnE's Avatar
gurnE
You need to cut the blue shroud off carefully.
http://wwwrsphysse.anu.edu.au/~amh11...l_injector.htm
Old Apr 3, 2005 | 04:09 PM
GARETH T's Avatar
GARETH T
parts laid out in order
Old Apr 3, 2005 | 04:11 PM
sirmark's Avatar
sirmark
My fittingkit looks like this:
http://www.cosworth-racing.dk/billedere/sc624.jpg
Old Apr 3, 2005 | 04:12 PM
GARETH T's Avatar
GARETH T
sirmark, yep thats it
Old Apr 3, 2005 | 04:21 PM
sirmark's Avatar
sirmark
How do you mount the yellow "thing" at the bottom of the injetctor? Is the blue "thing" supposed to be pulled off before mounting the fittingkit?
Old Apr 3, 2005 | 05:01 PM
Matt's Avatar
Matt
sirmark, you dont need the caps only the metal washers and rubber o rings, some people drill the ends off and fit them, i (well karl norris did it for me) just binned them as have many others
Old Apr 3, 2005 | 05:03 PM
big_wig_074's Avatar
big_wig_074
mine didnt use the end caps!
Old Apr 3, 2005 | 05:14 PM
sirmark's Avatar
sirmark
Can they be mounted in the manifold as they look here?
http://www.cosworth-racing.dk/billedere/IMG_2289.JPG
Old Apr 3, 2005 | 05:23 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
the plastic caps are also heat insualors and no to your picture
Old Apr 3, 2005 | 05:46 PM
sirmark's Avatar
sirmark
What am I supposed to do then?
Old Apr 3, 2005 | 05:52 PM
sirmark's Avatar
sirmark
Ok. But what does "binned" mean?
Old Apr 3, 2005 | 05:55 PM
TIFF's Avatar
TIFF
Chasing Radders
Cut them off
Old Apr 3, 2005 | 06:09 PM
Stu @ M Developments's Avatar
PassionFords Creator
Drill a 7mm hole in the bottom of them is my advice as they also retain the spacer and rubber in the correct position.
Old Apr 3, 2005 | 06:35 PM
Rs Gus's Avatar
Rs Gus
slice them of with a stanley knife and drill a hole in the pintle cap as stu said
Old Apr 3, 2005 | 07:35 PM
sirmark's Avatar
sirmark
Ok. Now I'm totally confused. What is it I'm supposed to drill a hole in? The yellow cap?
Is the blue shroud supposed to be cut off at the top (all of it)?
Old Apr 3, 2005 | 07:40 PM
Rs Gus's Avatar
Rs Gus
drill the yellow cap
and cut the blue shroud off
Old Apr 3, 2005 | 08:12 PM
Ima Racing700's Avatar
Ima Racing700
Run without the yellow caps is my advice being a Bosch Dealer.
Old Apr 3, 2005 | 08:23 PM
sirmark's Avatar
sirmark
thanks mate
Why is it that the yellow cap isn't made with a 7 mm hole from the beginning....
So I cut all of the blue shroud off or am I supposed to leave some where the o ring and the spacer is being placed?
I know I ask a lot, sorry! But I just want to make sure that I do it right, because afterwards it's to late
Old Apr 3, 2005 | 08:25 PM
Rs Gus's Avatar
Rs Gus
thanks mate
no cut it all off and use the cap
Old Apr 3, 2005 | 08:30 PM
Ima Racing700
sirmark......take off the blue shroud...leave cap off,the reason it aint the correct size is cause the injector is not for a cossie!!! ....on this part use 2 rubber o-rings to ensure a nice seal proof fit....on the top use the metal spacer and 1 o-ring.
Old Apr 3, 2005 | 08:38 PM
Rs Gus's Avatar
Rs Gus
use the cap as its a heat insulator
manuel boeckx
13
Oct 3, 2015 02:29 PM
john_3.0s
Aug 16, 2015 06:40 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
CrOwSoN15
Aug 14, 2015 06:52 PM
MadsBL
Wheels and Tyres
Aug 6, 2015 10:04 AM
