3dr shells and strut braces.....
now i know 3dr shells flex alot but will the inner wings and more importantly the strut top move with age?? im going to put a brace on mine tmoz but wanna know if im gonna have probs with it not fitting???
I heard years ago that Ford admitted that inner wing flex was a fault and carried out the repairs under warranty. My passengers side had split through when i bought the car. Only makes the issue worse by fitting wider wheels/tyres and uprated suspension. Strut brace is the way to eliminate it
when you say its made worse buy fitting uprated suspension ...do you mean coilovers
im taking off my konis next week and putting coilovers on !!!!!!!!!!!!!!! but i have got front and rear braces
plus im putting polys all round !
FOOKING JESUS THAT WAS A NIGHTMARE!!!
car in air and still over 16mm out
Managed to fit it but its under massive strain and i doubt the self tapers will hold
Gonna porta power inner wings out and put some big dirty bolts through strut tops, hopefully that will cure it
Will there be a noticable change in driving with it sorted?? id say so but in what way.
right time to sort the cuts bruises and grazes of the day
Gonna porta power inner wings out and put some big dirty bolts through strut tops, hopefully that will cure it Will there be a noticable change in driving with it sorted?? id say so but in what way.
Just my opinion for what its worth but i would have thought that the strut brace should be fitted with both wheels on the ground. reason being that when u jack the car up under the xmember, u are distributing the load through one point, a force that is never going to be replicated on the road & resulting in a certain (small) amount of flex to the inner guards. this could be the resultant 16mm difference u are experiencing. any other views?
mine went straight on and sits central to the strut tops
i tried offering it up with the car jacked up to see if it made any difference and it never moved
im with niall.b......fit it with wheels on the ground....like i did
personally i would fit one while the car is on the floor as it normally would be, if the struts move understand car weight there is something wrong in my opinion.
Force out on the road obviously will cause strut flex like harsh bumps and heavy braking.
All in my opinion, and im going to fit mine whilst on the deck.
Anyone want to do a group buy on the GGR\Philloy ones? i missed out on the last one and i want one badly
front inner wings flex like fuk
its a big problem even more on older cars
ryan if your car has been done proper then it should have double skined n welded 909 strenghtning panels on the inner wings and inner wing to a post
front
and forget the boy racer brace n fit one like this with 4 pick ups to the stut tops on each side
front
I have on that I bought from ML motorsport at Nat day 04 and have yet to fit it, I will soon, but when I put it on the strut tops, it looks like it's off and will be a pain in the arse to fit! LOL. I was also told to lift the car when fitting it.
What to do...lol
