removing spot welded wings
I've gotta remove some, never done it before what's best way as wings are genuine ford capri and want to sell them on, anything better than just a drill bit on the spot welds?
My mate bought a special spot weld drill bit and used that.
don't use a drill use an air saw between the panels once you have separated the start of the panel to get the saw in just take your time prizing the panel then cutting the spot weld , much neater job and only needs a dolly and hammer to straighten the flanges ,
use a spot weld drill bit and you dont need to hammer and dolly the flanges straight you can also get a spot weld chisel that is thin to go between the two skins once the welds have been drilled out
Live long and prosper!!
Carl the problem your faced with is that you would have 2 genuine capri wings with spot weld holes in them and a intact wing rail providing you have not drilled through.
What would u rather buy? A pair of wings with or without holes?
Depending on how your new panels are fitted it would be better to cut the wing rail off with wing.
Paul
Paul
Paul
Paul
The wings will have to have holes in, I'm sure there worth good money anyways as genuine ford aren't available anymore I don't think
competant bodger
cheers lads, I got this hope it does the job ok and leaves the wings tidy
Clarke 10pc Spot Weld Cutter CHT685: Amazon.co.uk: DIY & Tools
they are what i use almost daily make sure you centre punch the spot weld and i usually put a pilot in with an 1/8th drill bit not all the way through but just a bit to make a better centre pop mark,they are slightly cheaper at machinemart and they usually have them in stock, you can always weld the holes back up in the wing and sand them flat for selling on
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
nico12
31-12-2015 04:42 PM
