Building engine loom for Vipec V88
Old 24-12-2014, 09:45 AM
nixon_2wd
nixon_2wd's Avatar
Default Building engine loom for Vipec V88
Hi guys, I just picked up a ridiculously cheap new and unused Vipec V88 at only £785. It came with a water temp sensor and a 5 bar map sensor. Going on my Saph build w/ EFR7670, Mark Shead billet collector exhaust manifold and my custom MIS ITB intake.
Now, I will have to build the loom. This requires cutting all the wires to length and getting all the connectors etc. and shrink wrapping the wires (don´t know the proper term in English sorry).
How do you guys build your looms and where to you buy the connectors and shrink wrap? I would like to do it properly so a guide or such would be nice.
Going to run full sequential 8 injector, launch control etc! Proper engine management has been on my wish list for 10 years so finally getting there
Cheers and happy Christmas!
Old 24-12-2014, 12:58 PM
opposite lock
opposite lock's Avatar
Bargain there . Rod seems to know lots about wiring this type or a bespoke loom builder etc maybe helpful.
Old 24-12-2014, 01:43 PM
JamesH
JamesH's Avatar
Let Rod do it
Old 24-12-2014, 01:49 PM
Caddyshack
Caddyshack's Avatar
Agreed, I would send it to Rod, he did a lovely job on my loom.
Old 25-12-2014, 11:01 AM
stevieturbo
C**t
stevieturbo's Avatar
If you dont have all the crimp tools and gear...it really is best to get someone else to do it.
Plus you need some patience.
Old 25-12-2014, 04:50 PM
nixon_2wd
nixon_2wd's Avatar
I dont have any crimp tools, could you specify whats needed? I would really like to do this myself, picky as I am.. Here in Norway we dont have people dedicated to making looms, and if they did it would be way way overpriced.
Old 25-12-2014, 05:10 PM
Caddyshack
Caddyshack's Avatar
Post to Rod...job done
Old 25-12-2014, 05:18 PM
stevieturbo
C**t
Until you have all the connectors you need, you wont know what crimpers you need...therein lies part of the problem
Most or some you will probably get away with a generic crimper, others might require specific tools.
At least you have the ecu end, as the crimp tool for the round Tyco connector used is quite expensive
nixon_2wd (25-12-2014)
Old 25-12-2014, 07:16 PM
nixon_2wd
nixon_2wd's Avatar
What price did Rod ask, Caddyshack? Got any pics of yours?
Old 25-12-2014, 07:23 PM
nixon_2wd
nixon_2wd's Avatar
Thanks, I will have to look into this.
I´ve seen connectors on ebay from brandshatchperformance, I´ll send them an email maybe they can sort me the required tools etc.
Are these proper quality ones? Some others recommended?
Old 25-12-2014, 07:59 PM
JamesH
JamesH's Avatar
CW Looms are worth an ask too
Old 25-12-2014, 08:01 PM
stevieturbo
C**t
Any connectors I've bought from Brands have been perfectly fine, and very keenly priced.
Old 25-12-2014, 08:18 PM
nixon_2wd
nixon_2wd's Avatar
Remember that we drive on the other side here in Norway hence LHD car, so your usual RHD measurements all differ :/
I´ll contact them thanks!
Old 25-12-2014, 08:34 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I've a really good set of terminal crimping plier from Mac tools if you end up buying a set there worth a look
Old 25-12-2014, 08:38 PM
nixon_2wd
nixon_2wd's Avatar
Thanks, do you have a url?
Old 25-12-2014, 08:41 PM
ajamesc
ajamesc's Avatar
These ones I have. They do all different types for different terminals. I've these as they suit the terminals Daf use.
http://www.mactools.co.uk/rate-mac-t...crimping-plier
Old 25-12-2014, 08:51 PM
Mark Shead
Mark Shead's Avatar
I have done a couple of left hand drive cars and the loom you have will need extending as some of the wires are to short.
Mark
Old 25-12-2014, 09:01 PM
stevieturbo
C**t
That wouldnt do a double crimp at the same time though ? as most terminals need ?
ie strain relief and then actual bare wire crimp itself ?
http://www.mactools.co.uk/rate-mac-t...-crimping-tool
This style with interchangable heads would be a good all rounder ( there are much cheaper versions available I'm sure )
And usually their jaws are designed to do both crimps in one action.
You just need to get the correct jaws for what you're working with
eg cheaper version, but sometimes the jaws arent formed that great so dont always produce great results. It's just finding good quality versions is the issue
http://www.ebay.co.uk/itm/UK-Crimpin...item2a49510d8c
These look much better quality, and looks like easy change heads too which is handy.
http://www.ebay.co.uk/itm/Anvil-Quic...item58b38f48c3
Old 25-12-2014, 09:09 PM
ajamesc
ajamesc's Avatar
Its each too there own I guess I've used mine 100,s of time and find them very good you just move them along a little and there's your double crimp.
nixon_2wd
nixon_2wd's Avatar
Mark
Hi Mark, too short? Really, on a brand new Vipec loom?
Thank you for the info guys.
Old 25-12-2014, 09:18 PM
nixon_2wd
nixon_2wd's Avatar
I found this:
https://www.rbracing-rsr.com/sq6wiringloom.html
Seems to know what hes doing but looks quite expensive lol. All Deutsch Autosport connectors and Raychem DR25.
Old 25-12-2014, 09:31 PM
stevieturbo
C**t
Rywire make loads of stuff and could make anything you need
http://www.rywire.com/mil-spec-engin...ses-s/1820.htm
Old 25-12-2014, 09:41 PM
nixon_2wd
nixon_2wd's Avatar
Looks awesome but I dont want to spend that much money on a loom
I dont say theyre not worth it, just too much money.
Old 26-12-2014, 08:35 AM
Mark Shead
Mark Shead's Avatar
We have to route the wires diff on a lhd car so some wires are longer. Rod would have the details on the diff.
Mark
Old 26-12-2014, 10:07 AM
Caddyshack
Caddyshack's Avatar
I don't have any pics of my loom and don't know the cost as it was part of the whole fitting and mapping etc. suffice to say that it was factory perfect or better and all labelled and neat with proper braiding etc.
Old 27-12-2014, 07:22 PM
cossirob
cossirob's Avatar
Who is rod? Lol
Old 27-12-2014, 08:50 PM
Focosmitch's Avatar
Rod tarry..
Old 28-12-2014, 12:37 PM
nixon_2wd
nixon_2wd's Avatar
I dont mind getting the crimp tools required. It will be nice to have them in case something needs replacing.
Thinking of using Raychem DR25 for the whole loom. Also looking at the idea of making a new passage through the bulk head as the wires on LHD cars come out right behind the downpipe, passes over behind the engine and comes around behind the intake manifold.
As Mark says this makes the engine loom too long.
Cutting the bulk head makes it more like a RHD loom, hence no need to lengthen the existing wires (preventing even more possible complications).
Old 28-12-2014, 09:16 PM
stevieturbo
C**t
Is there not enough wire on the harness you have there to cover most of the loom ? It wouldnt make a lot of sense replacing all that ?
But swapping bulkhead entry away from the downpipe makes sense.
Old 28-12-2014, 10:06 PM
nixon_2wd
nixon_2wd's Avatar
I think what Mark said was that the wires are not long enough on the Vipec loom to be wired as normal on a LHD car. By making another bulkhead entry I wont have to splice wires.
Old 29-12-2014, 06:53 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Sorry about the delay have not been on over Crimbo.
At best very tight as the LHD loom is about 800mm longer than a RHD.
All looms are different depending on coils used & the position of sensors also number of injectors.
For me to make a loom factory fit I must measure the car & decide loom route & junction points. Its why I don't make looms for anyone else but Mark Shead. If you have not done one before be a bit wary & always draw a Circuit Diagram. There is only one +12v on each connector on a V88 & you will need at least 20 other +12v in a 8 injector V88 loom & that needs planning same with sensor grounds.
Old 29-12-2014, 08:18 PM
stevieturbo
C**t
20 x 12v ?
Surely there is only main 12v power ? Ecu always supply grounds, and 12v supply for actuators will come from the vehicle
Old 29-12-2014, 11:31 PM
James @ M Developments.
James @ M Developments.'s Avatar
It's quite complex getting it all to work and not suffer huge voltage drops though, many looms I see on weber all spur from pin 20, so the whole loom is fed from the ECU power and the voltage drop is horrendous, which is why I use split relays and power the ecu seperately, we see next to no voltage drop at all this way.
Also ground points are critical,
There is far more to making a good performing loom then many people think which is why I see so many bad performing ones lol
Old 30-12-2014, 08:59 AM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
What total tosh . You want to put your theory to the test on mine. Mines all fed from the ECU & went rather well thank you . No Volt drop on mine because it has very little load or are you just talking without the Electronic knowledge to back it up. Ground point is not critical its a single point earth & needs to be good not critical. All other grounds are sensor & not at chassis potential. You may fancy talk the average peep on here but ive 50 years of aircraft looms to back up my facts.
Old 30-12-2014, 09:26 AM
I thought you used a system to maintain stable voltage Rod?
It's not tosh at all, I spent over a year testing and developing my looms, and have data logged pretty much every point on the loom and know exact how most perform, don't forget I am talking about weber looms.
Engine bays are very dirty places as far as signal noise and RF is concerned and purely the fact that a more modern ecu can deal with it doesn't mean the noise doesn't exsist. Anyone with good electrical knowledge will tell you that.
Splitting the relays like I do on my looms means I only see around 0.2v drop from idle to 8000rpm, on most other even new looms is more like 2.0v and I know that because I data log everyone I map
Other people are also capable of making good products that work rod, not just you
Old 30-12-2014, 09:28 AM
Bailes1992
Bailes1992's Avatar
Voltage drop has nothing to do with load. More to do with the resistance of the cable the longer it gets.
Old 30-12-2014, 09:31 AM
Yes to a point you are right, and overloading cable, and using the wrong size etc
Old 30-12-2014, 09:34 AM
stevieturbo
C**t
of course it does.
The higher the load, the less able the conductor, the higher the volt drop from point to point will be.
Old 30-12-2014, 02:13 PM
nixon_2wd
nixon_2wd's Avatar
Thank you for that info, Rod. I will make a complete wiring diagram including lengths and colors of the whole loom.
You´re right about that. The loom definitely needs careful planning.
Would you guys favor individual coils over a coilpack? Which coils are recommended?
The plan is to run 8 sequential injectors.
Old 05-01-2015, 04:41 PM
nixon_2wd
nixon_2wd's Avatar
Bump! Also, are MAC boost solenoids any good?
Quick Reply: Building engine loom for Vipec V88
