HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 21, 2014 | 07:44 PM
Jay,'s Avatar
Jay,
Sponsor
Default HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Stripping out the engine loom on the cossie come across a few issues
Right this the lamba plug
And found this behind the battery
Some of the cable goes the to the plug iin the first plug and the rest come out of the engine loom
any help and whats what will be brilliant as im fuckin stuck badly
Old Dec 21, 2014 | 08:02 PM
Paul_RS's Avatar
Paul_RS
IIRC Plug behind the battery is for the clocks - Tacho wire, water temp, oil light.
Lambda plug is there on all 4x4's but only used on the facelift (green cam cover) engines.
Old Dec 21, 2014 | 08:33 PM
Jay,'s Avatar
Jay,
Sponsor
cheers paul theres some thick live wires there thiough
Old Dec 21, 2014 | 08:36 PM
james kiely's Avatar
james kiely
any chance jay that its a breakout terminal for checking ecus by ford technicans as it looks similar to the ecu to loom connector behind the dash
Old Dec 21, 2014 | 08:38 PM
Paul_RS's Avatar
Paul_RS
IIRC (again ) they are for the Bank of relays under the dash near the ECU.
I take it you are changing to an aftermarket loom?
Old Dec 21, 2014 | 08:42 PM
Jay,'s Avatar
Jay,
Sponsor
Yes mate new ecu and loom and im not sure if i have to live any of that up or take lives ect for the new ecu
Old Dec 21, 2014 | 09:10 PM
Paul_RS's Avatar
Paul_RS
I'm pretty sure I used those lives for my Prometheus loom. However, the loom we are putting into the old Reyland Cosworth has it's own new lives to connect up.
You'll really have to look at the new loom and go from there!
Old Dec 21, 2014 | 09:14 PM
Jay,'s Avatar
Jay,
Sponsor
I might be looking to far into it Paul and getting stressed with it and dont want cut or unplug stuff that will effect the car in other ways
Old Dec 21, 2014 | 09:16 PM
Paul_RS's Avatar
Paul_RS
It won't affect anything. The only 'integrated' bits on an original Cosworth engine loom are the dash clock gauge wires. You can remove the loom everything on the car bar the engine lol will still work
Old Dec 21, 2014 | 09:19 PM
Jay,'s Avatar
Jay,
Sponsor
Great Paul thanks for your time much appreciated
Old Dec 21, 2014 | 09:26 PM
Paul_RS's Avatar
Paul_RS
No problem - I've been staring at this for weeks so it's all pretty fresh in my mind
https://passionford.com/forum/restor...-cosworth.html
The looms are actually done quite a smart way by Ford. All the looms seem to be seperate. The ABS system wiring, engine wiring, charging/starter, lights and fan looms etc are all separate bits. Whereas on an Escort they are all together and a massive pain in the arse if you want to change management
Old Dec 21, 2014 | 09:42 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
This might help Jay
Old Dec 21, 2014 | 10:55 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Jay are these the colours on that plug - you may not have all those colours.
Green- Rev Counter
Br/Wt- Water Temp
Blk /Red - Fuel Pump
Black - Ignition
Blue - Batt L;ight
Red/Blu- 12v
Brn/Gn- Oil Pressure Light
You can make the connections to your new loom for Rev Counter, Water Temp & Ignition at this plug saves going to the binacle. Just look at your circuit diagram.
If in doubt give us a bell.
Old Dec 22, 2014 | 10:24 AM
AlexF's Avatar
AlexF
why is the loom out?! lol
Old Dec 22, 2014 | 10:37 AM
Jay,'s Avatar
Jay,
Sponsor
Thanks to everyone Rod on the end of the phone and I am on the the way to sorting it
Should of got a 2wd less confusing:cr y:
Old Dec 22, 2014 | 02:02 PM
costina's Avatar
costina
Live long and prosper!!
glad u got it sorted as i was going to reply.
Dont the 4x4 engine loom go into.the main fuse box for relays.
Old Dec 22, 2014 | 02:18 PM
Jay,'s Avatar
Jay,
Sponsor
By the looks of it it is partly and has fuel and coil relays on the engine loom to
Old Dec 23, 2014 | 08:28 PM
Eagle's Avatar
Eagle
Super Moderator
its jay ... im confused as to why your asking mate
by now its probably been stripped and most of it sold ...
