Polycarb windows
Old Nov 21, 2014 | 03:58 PM
Gaz 88's Avatar
Gaz 88
Default Polycarb windows
Do the fronts work on the oe manual winders and rails or do they have to be bolted or bonded?
Old Nov 21, 2014 | 04:11 PM
Piston Broke's Avatar
Piston Broke
What car mate ?? i run pol windows but they screw in under inner rubber bottom
Old Nov 21, 2014 | 04:17 PM
Gaz 88's Avatar
Gaz 88
It's a ford focus RS mk1
Old Nov 21, 2014 | 04:49 PM
Piston Broke
These are the boys mate http://www.acwmotorsportplastics.co.uk/
Old Nov 21, 2014 | 04:55 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
If you run them on manual winders they'll scratch like fuck within a short space of time, better off with sliders on them. Or just glass if it's a road car, the gains do not warrant the pain in the ass lol.
Old Nov 21, 2014 | 06:01 PM
Gaz 88's Avatar
Gaz 88
It's a track car but also used on the road so wanted windows for security if it gets left anywhere!
Old Nov 21, 2014 | 06:07 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I think you'll have a real problem with scratches if you have them on the roller mechanism, do you need them to actually open?
Old Nov 21, 2014 | 07:06 PM
Gaz 88's Avatar
Gaz 88
I was just thinking to stop steaming up! Was thinking a little heater matrix in the car and a roof scoop do you think that should be enough?
Old Nov 21, 2014 | 07:11 PM
Rs1's Avatar
Rs1
As above with re: to scratches.
Ive seen options for bonded, bolted, riveted but if you real keen and want to keep a retrofit option for the OE glass you could use the mechanism to hold the polycarb in place. This would require the ploy to be cut to the same shape/size as the glass though for secure fit.
Old Nov 21, 2014 | 07:14 PM
Rs1's Avatar
Rs1
http://www.t7design.co.uk/index.php?...roducts_id=180
Old Nov 21, 2014 | 07:46 PM
nevsrevs's Avatar
nevsrevs
acw is the only place to go imo.
Old Nov 22, 2014 | 09:42 AM
Gaz 88's Avatar
Gaz 88
These are the heater matrixs I have seen they look good!
Gaz 88's Avatar
Gaz 88
How did you secure your front ones seen your car on the website
Old Nov 22, 2014 | 10:40 AM
Fast Guy's Avatar
Fast Guy
I have Lexan manual windows in my car and they haven't scratched much after about 8years maybe. Main problem is, if you wind them down on the move, the wind bends them enough that you can't get them back up properly as they come out of the runners slightly.
Old Nov 22, 2014 | 05:07 PM
Cos500's Avatar
Cos500
Really wouldn't bother, fitted these to my 205 mi16 track car, they rattle, mist up, scratch, and apart from looking the part was no weight loss over the original glass.
Old Nov 23, 2014 | 06:15 AM
gus's Avatar
gus
On my escort I would guess at about 50% reduction in weight
Old Nov 23, 2014 | 08:13 AM
Fast Guy's Avatar
Fast Guy
Mine weigh about half too. Probably less than a 10kg weight saving over all, but it all adds up when you do lots of little bits.
Old Nov 23, 2014 | 09:47 PM
nevsrevs's Avatar
nevsrevs
ours are bolted and bonded mate.
Old Nov 24, 2014 | 04:45 PM
Gaz 88's Avatar
Gaz 88
Polycarb are deffo lighter! What company's are there for polycarb windows?
Old Nov 24, 2014 | 06:49 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
the weight of the glass alone is only the small part of the saving. With a fixed (plastic) window you can now strip out the window regulator, door wiring, loom wiring for windows etc etc.
Then if your race series allows, cut the door up to a bare shell and go skitzo with a hole saw and swager.
The indirect weight savings are the main benefit.
Old Nov 26, 2014 | 10:02 PM
Focosmitch's Avatar
Id use plastics4performance, acw windows arent thermoformed.
chowfornow
14
Jan 5, 2019 09:01 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
