Need help failed vrt/mot
Old Nov 6, 2014 | 02:28 PM
Errol Taliana's Avatar
Errol Taliana
Default Need help failed vrt/mot
I have an escort mk 6 1.4 fuel injection year 1995.Today I went for the mot and it failed on the emission test CO is at 0.54% and Lambda is at 1.036%.Can someone please tell me what could the problem be. I changed the cat and lambda about 4 years ago too
Old Nov 6, 2014 | 05:10 PM
stevieturbo's Avatar
stevieturbo
C**t
4 years is a long time for a lambda sensor, especially a non OEM one.
And likewise, pattern cats are often crap compared to OEM.
Old Nov 6, 2014 | 06:11 PM
Errol Taliana
so you thing its either one of these the problem i have ?
Old Nov 7, 2014 | 10:44 AM
St3V3_C's Avatar
St3V3_C
Was it driven hard before being tested? The cat needs to be really hot - can make the world of difference.
Old Nov 7, 2014 | 11:37 AM
stevieturbo
C**t
It could be a dozen things including either of those.
Test the sensor to see if it is working, or just replace it and test emissions
Old Nov 7, 2014 | 01:42 PM
Errol Taliana
well i did drive it to do some errands before i went to test it but was almost stuck in traffic the whole time.I am taking it to someone to check it out on monday will see what he finds now cause i aint going to start buying parts if im not sure . The lambda sensor cost 90 euros from bosch too
Old Nov 7, 2014 | 03:16 PM
stevieturbo
C**t
a few are listed, seems mostly wire length changes as opposed to sensor.
http://www.lambdasensor.com/main/bos...tem=0258003485
Any decent mechanic should be able to test if the sensor is responding correctly though
Old Nov 7, 2014 | 04:03 PM
Errol Taliana
what do you mean by wire length changes ?
Old Nov 7, 2014 | 07:28 PM
stevieturbo
C**t
length of wire on the sensor.
Old Nov 7, 2014 | 09:27 PM
Errol Taliana
does it make any difference if lenght is not as original one
Old Nov 8, 2014 | 08:03 AM
stevieturbo
C**t
Well..only if it doesnt reach lol
Old Nov 10, 2014 | 03:01 PM
Errol Taliana
ok well today the mechanic i took the car too tested the car and he told me that the lambda came up faulty but than he changed the lambda for another one and went to check the emissions and co was still high.He than disconnected the air filter only just after the maf and the car went crazy.It started to act up on him for example when he grabbed the maf and move it around still connected the co either went too high or dropped a bit .He is thinking the maf is going bad.Any ideas now ?
Old Nov 10, 2014 | 04:05 PM
stevieturbo
C**t
Find a better mechanic ?
And airflow meters arent generally designed to be thrown about the place.
Has he checked the unit itself to see if it's output is sensible ?
Old Nov 10, 2014 | 04:12 PM
Errol Taliana
i didnt say he throwed it about the place he just grabbed it still attached to the inlet going to the throttle body and moved it abit
Old Nov 10, 2014 | 04:18 PM
stevieturbo
C**t
Airflow meters and their air filter/pipework are carefully designed to promote smooth and even airflow over the sensor. If you start waving one about introducing turbulent air, then they cannot work correctly. Some will be more fussy than others.
Yes there may also be a problem with the unit, this is why rather than waving it about a proper test would be conducted.
Old Nov 10, 2014 | 04:51 PM
Errol Taliana
anyone know where i can buy these types of sensors instead from where i live which is malta please.Everything is to much expensive here
Old Nov 10, 2014 | 05:39 PM
stevieturbo
C**t
Would the link I posted above sell abroad ?
A generic 4 wire sensor shouldnt be expensive ? Ł30-40 But really, test properly before buying.
Old Nov 11, 2014 | 03:34 AM
Errol Taliana
the link you gave me is only for lambda sensor i need one that has maf etc just in case i need to buy one if it is really faulty.These sensors need to buy them as new not used
Old Nov 11, 2014 | 09:22 AM
stevieturbo
C**t
Ahh right.
I'm not sure of any cheap reliable sources for MAF's.
Often you will find that cheap aftermarket replacements are just shite and not worth buying. You may get lucky, but it is often the case.
But again, test to see if all is well before throwing money away.
Old Nov 11, 2014 | 03:08 PM
Errol Taliana
I am trying to get a hold of a maf to try and see exectly if mine is wrong or not but was checking on a site onlinecarparts.co.uk and found some mafs etc in it but not oem some brands like vemo vaico hella etc and was wondering if any of these are any good they are not that cheap but they are cheaper than oem for sure.I know the oem lambda sensor is made from bosch so thats not a problem but i would like to know what brand makes the oem mafs
Old Nov 11, 2014 | 03:15 PM
stevieturbo
C**t
If it doesnt already say on it....could be a few makers.
But again, just have the mechanic test it before buying.
Old Nov 11, 2014 | 03:19 PM
Errol Taliana
i dont think oem ones say who the manufactor is on them
Old Nov 13, 2014 | 03:42 PM
Errol Taliana
ok maf tested and its ok he also checked the injectors and found them good and he said the last thing we can try is changing the catalytic converter.I went to change it right after i got the car back from him so will have to see tomorrow hope everything will go fine cause than we are at a loss
Old Nov 14, 2014 | 02:42 PM
Errol Taliana
still bad news guys still failed mot on high co even after new cat fitted
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
SMILER258
Sep 28, 2015 09:04 AM
oldskooldanrst
Sep 27, 2015 04:02 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
davidfordrs
Sep 21, 2015 04:23 AM
