Ford Focus RS MK2 problems
Old Oct 28, 2014 | 11:57 AM
Vlad Stoica's Avatar
Vlad Stoica
Default Ford Focus RS MK2 problems
Hello guys,
I have a problem with my RS. I shift at 4000 rpm and then in the upper gear I have only 1200 RPM.
The engine stops everytime I brake and my radiator leaks. All this problems appeared at once, I never had a problem with the car till now.
The car has 42.000 km
Can you help me with some information?
Old Oct 28, 2014 | 12:41 PM
Rowe's Avatar
Rowe
Skint
Originally Posted by Vlad Stoica
Hello guys,
I have a problem with my RS. I shift at 4000 rpm and then in the upper gear I have only 1200 RPM. may be boost solenoid, get the fault codes read
The engine stops everytime I brake probably an air leak somewhere, and may be linked to your lack of revs, get the codes read
and my radiator leaks check the radiator for leaks. They have a tendency to split when aftermarket intercoolers have been fitted.
Old Oct 28, 2014 | 01:23 PM
Vlad Stoica
Thank you for your answer. I will check them and reply if I have any other questions.
Old Oct 28, 2014 | 01:35 PM
3FRD's Avatar
3FRD
Is it green?
Old Oct 28, 2014 | 01:47 PM
Vlad Stoica
It`s blue. Why?
Old Oct 28, 2014 | 01:50 PM
Rowe's Avatar
Rowe
Skint
no problem
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
