Focus RS Mk2 & Ford Kuga Hub sizes
I need to make some driveshafts for a car using Focus RS Mk2 Front hubs , im told the Kuga uses the same size splined C.V ends ,can anyone confirm this for me please ??
I think you're correct. Wolff tuning do a 4x4 convertion for the mk2 frs using kuga running gear etc.
Great info guys .
So then , do you know if the outer C.V's are the same , i thought focus Rs Mk2 used a Bolted outer C.V and the Kuga was retained by a Nyloc nut ??
Either way i need a supply of outer C.V's of either, knackered or bust or New doesnt matter while im dummying these up, initially only to keep the wheel bearings together when the cars on the floor .
Thanks
Thanks
