Sponsored by:
Sponsored by:
Mk4 fiesta help
Old 01-10-2014, 07:37 PM
Dermot_674
Dermot_674's Avatar
Angry Mk4 fiesta help
Hi guys, I have a mk4 fiesta 1.25. When I turn the ignition on the temp gauge goes straight to hot, without the engine running with a stone cold engine
It's not overheating it's more of a electrical problem. Still does the same if I disconnect the temperature sensor on the thermostat housing?? Please help it's driving me insane!!
Old 01-10-2014, 07:52 PM
Moderator
STeve's Avatar
could simply be a fault on the speedo cluster which is common and the whole unit 2nd hand is peanuts and easy to change,
Old 01-10-2014, 08:03 PM
gjh
gjh's Avatar
I'd try that^ Does sound just like a dodgy speedo cluster.
Old 03-10-2014, 01:40 PM
corkfordfan
corkfordfan's Avatar
Not sure about the 1.25 but the 1.3 had two coolant sensors, one was the switch for the fan the other was a sensor for the gauge and engine management
Old 03-10-2014, 01:50 PM
James @ M Developments.
James @ M Developments.'s Avatar
Check the signal wire to dash hasnt gone to ground somewhere.
sridgett
01-10-2015 07:30 PM
Steve Escos
01-10-2015 06:57 AM
Marv888
26-09-2015 03:44 PM
Quick Reply: Mk4 fiesta help
