160bhp 1600 zetec se
What will it take to get that sort of power out of one? I'm asking on behalf of a friend, and I (someone correct me if I'm wrong here) the standard inlet won't flow enough for that. Any ideas what is required? My guess was ITBs along with an ecu, head porting (stanhard sized valves), fast road cams (shawspeed ss4?), decent manifold and exhaust. Wil the standard bottom end cope with that?
Cheers in advance people!
Cheers in advance people!![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Cheers! I've heard the heads are pretty good actually.
Thanks!!! I'll pass the message on
You'll need a damn good exhaust and ex manifold to do that but yes shawspeed ss4 cams will get you there, also looks at valve springs and rod bolts, if you are on a 3rd party Ecu and can raise the std rev limit you'll just about do 160.
Ben
As above, you'll only just about touch 160 with the spec mentioned.
LS4's are an alternative, I can't remember whether they're as aggressive as SS4's though.
Definitely look into aftermarket management.
cheers for the help folks!!!
mk3ste
17-10-2021 10:09 AM
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
