Important Info re the safety of YOUR YB
When looking at engine builds or upping bhp on current engine always use a fuel pump that has extra capacity than you need.I read so many posts on here regarding what pump should you use...its simple use a 044 grp a for stage 3 320bhp to 600bhp.The reason being that a car thats used for say track days or long thrashes will heat the fuel pump up and you can loose around 30litres/hr pressure...and running close to the edge ie speccing it with not enuff reserve can end in melt down.
Remember the std Cossie came with a pump cabable of flowing around 380bhp flat out......so whatever happened the pump would never loose enuff pressure to melt the engine.
DEYTUKURJERBS
If you want some serious pumps, get a Weldon, do single pumps good for upto 2500bhp
http://www.weldonracing.com/oc.html
I am Trade only Broomy..have been for a while now infact ever since my TRADER status was removed by my request...so not an advert at all...just sound advice from blowing a YB apart because you dont realise the rights and wrongs
have to agree with IMA here, when i had my car initially mapped, my tuner thought i had a huge problem with something as he said i should be well into the 400ponies with my set up, then when he asked when was the last time i had changed my fuel filter, i said never, then said what about when you uprated your fuel pump??? i said i hadn't , he laughed and then told me he would leave the car at 375hp and to go back when i sorted my pump and filter out as it was maxing out at that
Originally Posted by lloyd
how much bhp will twin standard pumps supply?
I`m going to get some walbro 255l high pressure pumps, and fitting one to my car.
I want to run an anti surge tank supplied with 3 vectra fuel pumps, then use a walbro pump to supply the fuel to the engine.
The plan i have is to pressurise the swirl tank to 5 - 20 psi.
Thant way the pump will have less pressure differential to operate to supply the fuel to the engine.
Darren
Darren
Testing the future
What about uprated Esc cos pumps that sit in the tank do these over heat as well?
the problem is then that hot fuel is less dense than cold fuel, so the same injector duration will flow less fuel mass at higher temperatures, which could result in lean mixtures and meltdown problems. after all, we need to match the mass of fuel with the mass of air (oxygen), not the volume.
so having a massive fuel pump is not necessarily a good thing.
if you have one that flows just over enough for a massive power on boost engine, it will be flowing way too much for low speed low load conditions and all that you will do is heat the fuel.
2 solutions:
1) do as rolls royce and bentley use to do (and maybe still do, i haven't looked for a while) and fit fuel coolers in the suction line of the air conditioning.
2) have 2 fuel pumps. 1 for low load conditions and a 2nd triggered much like water injection on boost, rpm, throttle position or whatever. that way you have enough fuel flow for high load, but not too much at low load to cause excessive heating of the fuel.
this becomes more of a problem the bigger the difference is between low load and high load fuel mass flow requirements. i.e. more of a problem on a t4 cossie running 2 bar boost than a t3 running 1 bar.
not as easy as you first thought is it?
