bosch 803's what do they flow?
Originally Posted by abdr500
400 bhp is a no no as i made 354 and i was running lean at top end. you can make it with 8 greens
leecavturbo, light blues for 400bhp and greys for over both need fitting kits
Greys are 503cc IIRC.
Yep, greys are 503cc/min
Here is the differences:
http://wwwrsphysse.anu.edu.au/~amh11...l_injector.htm
Originally Posted by Toe Knee
As said 350bhp is about their limit, althou didnt rainbird or hadland make 380 running greens once upon a time?!?!
Can't see the point in buying an injector to run it at near max duration imo, better to buy something more suited to the power you're lookingh to achieve
Originally Posted by Andreas
Just remember that most flow figures for injectors are done at 3 bar fuel pressure and the cossie run 3.5 bar.
greys @ 3,0bar = 503cm3
greys @ 3,5bar = 543cm3
wheelwizardrefurbs
23-09-2015 09:21 PM
